Zeno watch not working
Discussion in 'Watch Repair' started by Martinus, Aug 29, 2017.
  1. Martinus
    Martinus Registered User
    Aug 16, 2017
    12
    I've recently bought a Zeno watch from a garage sale.
    Balance wheel mechanism is ok. But the crown isn't winding the watch . It moves the hands and changes date. Need help.
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,916
    watchmaker
    Western NSW, Australia
    Sounds like either the cover plate is broken or the yoke has slipped out of position or both. You'll need to take the dial off for a look. Why not show some photographs?
  3. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    2,898
    Gothenburg
    What about a broken mainspring?
  4. Martinus
    Aug 16, 2017
    12
    Thanks.
    The problem is as follows
    When the stem shaft is in winding position
    It can move to the left smoothly but can't
    rotate to the right to wound the watch.
  5. roughbarked
    Dec 2, 2016
    1,916
    watchmaker
    The mainspring is fully wound and the watch is stopped. Let the mainspring down fully and it should now be able to be rewound fully. The watch needs servicing or repair. The situation is normal with the winding.
  6. Skutt50
    Mar 14, 2008
    2,898
    Gothenburg
    After having read this I agree with roughbarked that service is needed!
  7. Martinus
    Aug 16, 2017
    12
    Thanks lot to you all.
  8. Martinus
    Aug 16, 2017
    12
    Hi Roughbarked
    I've tried very hard to unwind the mainspring but to no avail.
    It looks like stuck. I cleaned the watch in a cleaning solution and oiled it.
    Every part i working nicely except the mainspring.
    Any new advice please.
    Thanks in advance.
  9. roughbarked
    Dec 2, 2016
    1,916
    watchmaker
    #9 roughbarked, Aug 31, 2017
    Change the battey then.
    How do you know anything is working if the mainspriing is stuck? Have you searched letting down mainspring on this site?
  10. roughbarked
    Dec 2, 2016
    1,916
    watchmaker
    Sorry if I sound abrupt.
    If the mainspring appears "stuck" when fully wound, there are several possibilities. The first one of which is that the watch isn't in working order. Washing it in a bucket and saying it has been cleaned while the mainspring is still "stuck", is only gibberish. It is impossible to clean and oil a watch movement while the mainspring is "stuck".
    For a start, one needs to take the movement out of the case and remove the dial and hands. It is going to be a complete mess otherwise.
    Please show your photos and your workings.
  11. Martinus
    Aug 16, 2017
    12
    Well .
    I know by using my small air pump on the balance.
    The balance oscillates and all parts work well. Simply that.
    And when rotating the automatic plate the watch works.
    This far i went to know. Any conclusions you make are most welcome.
    I'LL try to post some pictures later on.
    Thanks a lot.
  12. Martinus
    Aug 16, 2017
    12
    Sorry for the delay posting images due to Summer vacation..
    Here are some pictures
  13. roughbarked
    Dec 2, 2016
    1,916
    watchmaker
    It looks like a Felsa 4000 series movement. It is auto wind and though it does have a manual winding system it is easier to wind manually if the automatic system is removed. The semicircular weight will rotate and wind the watch when worn on your wrist. The manual winding system may be rusty or have broken parts if the watch cannot be wound manually.
Similar Threads - Zeno watch working Forum Date
Demagnetising a watch--the cheap way Watch Repair Wednesday at 6:40 PM
Doctors watch stop mechanism Watch Repair Nov 2, 2017
Fusee Pocket Watch Hands Watch Repair Nov 2, 2017
ELGIN WATCH Watch Repair Nov 1, 2017
Bulova Accutron 214 "Working Stem" Watch Repair Apr 24, 2017
