Zenith calibre 3841 Pocket Watch (shock protection)
gmorse
15,246
4,362
Hi Stephen,
If you need to do this, before replacing the balance it's worth looking closely at the staff pivots to see whether they've picked up any debris from the bench covering, because anything sticking to them will get back on the jewels. Strictly speaking, you should re-clean and lubricate everything in these circumstances, but while there's a question mark over the stability of the watch I should carry on with the testing.
svenedin
Jan 28, 2010
1,941
706
Surrey
Good. I thought that too. I have put the dial and hands back on, it's back in the case and in my pocket and I shall give it an extended test of real life use. If it overbanks again then I will have to investigate further.
svenedin
Jan 28, 2010
1,941
706
Surrey
So far so good. The watch running normally for 24 hours. It ran 5 days before overbanking first time round. I think my provisional diagnosis is that I forgot to tighten down the balance cock screw. The screw loosened over 5 days carrying the watch around in my pocket. Then when I put it dial up on my bedside table the balance cock tipped down allowing too much endshake on the balance and the dart missed the safety roller probably with the minor impact of putting the watch down. I did notice a strange metallic pinging from the watch as I was going to sleep but ignored it only to find the watch stopped in the morning. That pinging was presumably the balance hitting the wrong side of the fork as it came to rest after overbanking.
Having to partially take the watch apart again has been a learning experience. I used too much oil on the shoulder of the barrel arbour (my book recommends HP1300) and I found a little oil on the back of the dial. I also used a bit too much grease on one or two posts of the keyless works and some creep was evident (but not much). I think the hand tension is a bit "light". It's very smooth but perhaps too easy. The hands don't slip but again I may have been over generous with canon pinion grease. Having said all that, there was far more oil and grease around the watch when I first received it! Under the crown wheel looked more like the inside of a motor car wheel bearing.....
I'll keep the watch on test for now but I think I'll be heading towards a full strip down again as I am too obsessive and fussy to tolerate my sloppiness!
Skutt50
Mar 14, 2008
4,472
597
Gothenburg
If the movement has a tendency to overbank, one situation when this happens is when the mainspring is worn down and the watch comes to a halt.
svenedin
Jan 28, 2010
1,941
706
Surrey
Yes. Thank you Skutt. I actually read some of your old posts on this. When the watch overbanked it stopped at 11pm so it was at roughly half-wind (assuming 30 hour run time). It should not have been low on power at that point.
Chris Radek
Apr 13, 2014
1,291
774
Lincoln, NE, USA
timeguy.com
Just a few thoughts:
If the hand setting is loose, that's not because you've used too much grease. Too much grease causes a mess, but not looseness. Looseness is because the cannon pinion is worn from there NOT being proper lube previously, and now it needs to be tightened.
If it overbanks, that is a fault in the safety mechanism of the escapement, which is made up of a roller with a cutout for passing (the one with the jewel, on single roller; the small one on double roller) and corresponding pin or dart, and also the general condition of the jewels and pivots that keep the safety parts in their proper places with respect to one another. When you service the escapement, check it for safety - try to pass the lever to the wrong side throughout all the balance's positions. Concentrate especially on the positions where the fork and jewel are interacting. In a correctly functioning escapement it will not be possible to move the fork to the wrong side in any situation.
svenedin
Jan 28, 2010
1,941
706
Surrey
This watch stopped. It had overbanked again and was making an odd noise but this time the cause was really very obvious indeed and rather silly on my part! I had not tightened one of the pallet bridge screws and I found it loose in the movement.
I fixed that and then on further testing the mainspring has started to slip on the arbour. I have had very limited success trying to tighten the centre coil of a mainspring before and have ended up breaking them or deforming them out of round. I will try to tighten the centre coil by squeezing it with pliers whilst it is around the tapered arbour from my spring winder. It may break so before I do that I have ordered another spring...Quite a nuisance to have to get the spring out again but the barrel will pass underneath the centre wheel so no need for too much disassembly.
Does anyone have any tips they could share about how to tighten the centre coil of the mainspring to ensure a tight, secure fit on the arbor?
gmorse
15,246
4,362
Hi Stephen,
You can buy curved jaw pliers, which have one convex and one concave jaw. To make a permanent bend in a spring you have to bend it past its elastic limit, (without it fracturing!), so bending it on an arbor probably won't work. The centre coil is particularly vulnerable because of the hole where it hooks on.
svenedin
Jan 28, 2010
1,941
706
Surrey
Thank you Graham. I have investigated and the spring was in fact securely hooked on the arbor. I am thinking that in fact the spring was slipping on the barrel hook. It would take about a 1/4 wind and slip. I think the hook end of the spring was squashed so flat as it fed into my winder that it was no longer an effective hook. The barrel hook looks fine. Then again maybe it was slipping on the arbor with sufficient tension in the spring. I am not sure. Needless to say I did try to tighten the inner coil and........I broke the spring through the hole.
Thank you for the link to the pliers. Would their profile achieve a tight enough curve?
As well as ordering the "correct" mainspring by dimensions (Zenith will not sell the branded mainspring) I have ordered a slightly shorter (40mm shorter) of the same height and thickness but for a 15 barrel rather 16. I am hoping the spring for the smaller barrel may have a tighter inner coil already. Just a guess!
gmorse
15,246
4,362
Hi Stephen,
That does depend on how tight it needs to be! If it's the hooking in the barrel wall that's suspect, it may be the hole itself or the hook that's at fault, as well as the final curve; have you any pictures?
svenedin
Jan 28, 2010
1,941
706
Surrey
Hello Graham. Yes the hook from the original spring and replacement look different. For want of a better term, the "barb" of the original spring is obvious but in the replacement it is ineffective. The original spring has the hook end almost flat but in the replacement it is curved.
Original spring:
Replacement spring:
gmorse
15,246
4,362
Hi Stephen,
The end of the bridle ringed in red, where it engages with the hooking in the barrel wall, may need chamfering so that the outer edge is sharper and bites better in the hooking. Is the hooking in the barrel wall a stud or just a step in the metal?
svenedin
Jan 28, 2010
1,941
706
Surrey
Thanks Graham. It’s a stud. Too small for me to photograph. From the outside of the barrel there’s a hole/slot that the internal stud is fitted into somehow.
gmorse
15,246
4,362
Hi Stephen,
If it's a separate piece, these are usually either screwed and/or riveted in place, although in some cheaper watches they aren't separate, they're just punched into the barrel wall.
svenedin
Jan 28, 2010
1,941
706
Surrey
I had another look today. The mainspring is definitely slipping on the barrel hook not the arbour. If I wind the watch until it slips then let down the spring the tail end has clearly slipped past the barrel hook. Unfortunately, the barrel hook is not a stud as I first though but punched into the barrel wall. If I could get parts I would replace the barrel but parts are near impossible to find for this rare movement. There is a scrap movement on the well known auction site but it is rather expensive for what it is and there is no way of knowing whether the barrel is in good condition. I used a punch to punch the barrel hook from the outside of the barrel so that it protrudes slightly more into the barrel. This has actually worked and the spring now holds but I don't like my crude "bush fix" very much. I will keep looking for a new barrel as one may turn up eventually.
Skutt50
Mar 14, 2008
4,472
597
Gothenburg
It probably is not a problem. Sometimes these barrel hooks are worn or damaged and needs a bit of help to function properly. As Graham pointed out earlier it may help to chamfer the outer edge so it grabbs better. Also bending the outer edge slightly "outwards" can do the trick.
svenedin
Jan 28, 2010
1,941
706
Surrey
Thank you Skutt and thank you to everyone for your patience with my adventure with this watch. If the spring slips again I will try these suggestions. At the moment the watch is ticking away in my pocket. About time too!
svenedin
Jan 28, 2010
1,941
706
Surrey
Just to finish off this thread I did manage to find a used barrel complete.
This has the advantage of not only a good condition barrel with a hook that works but the original Zenith spring. None of the generic springs that I bought had the same form as the original spring nor did they appear to be made of exactly the same material. Whether this actually matters I do not know.
I cleaned up the replacement barrel and spring. Fitted it. Tested and all was good. Then (tempting fate perhaps) I re-oiled the balance endstones (since the balance had been out), lost a Kif spring (again), found the Kif spring and re-fitted. Re-oiled the pallet stones (they been out too and degreased) and the centre wheel bottom pivot (bridge had been off).
Just for interest here are 3 springs. The top one is the Zenith spring. The bottom 2 are both Generale Ressorts springs with exactly the same dimensions as the original spring. As can clearly be seen, they are NOT of the same form nor are they consistent between each other!
I had thought that as long as a spring was the same dimensions then happy days but no.......
svenedin
Jan 28, 2010
1,941
706
Surrey
Since I replaced the barrel (which also had the correct Zenith specification mainspring) the amplitude is significantly better. It just needs some adjusting for rate now. I am now getting 345 degrees DU and 325 DD compared with around 280 DU before the barrel swap. This is based on default 52 LA on the machine which I know is too high but this is about relative amplitude rather than absolute.
The old barrel was significantly worn, not just the barrel hook which was unreliable and started letting the spring slip (the hook is the type that is a little tab that has been pushed out from the wall of the barrel leaving a little hole). Although it didn't seem to have too much side shake or end shake I suspect it did actually because clearly the watch has more power. Then again it may be the spring too. The springs were exactly the same dimensions but not the same shape or on visual inspection exactly the same material (both alloy). I suspect the Zenith spring is stronger (it feels stiffer and more springy).
svenedin
Jan 28, 2010
1,941
706
Surrey
I went to regulate the watch today. Popped the case open and put the watch on the timing machine. Nothing. Switched machine off and on several times and nothing. Then looked at the watch which had stopped. Deep sigh. What has gone wrong now?!!!!! For crying out loud! :mad:
Looked at watch in case, balance would swing but escape wheel not moving. Totally puzzled.
Took watch out of case. Looked at hands, seems fine. Moved hand around, not catching. Took hands off in preparation for getting dial off. Watch now working I notice. Hands? No. This..................(notice my avatar; it's a white German Shepherd Dog hair)
svenedin
Jan 28, 2010
1,941
706
Surrey
Hi Stephen,
She's just making sure you haven't forgotten her!
Yes indeed! I do have the current, boy, white GSD but my avatar is still the old girl. He never lets me forget about him. He’s far too noisy for that!
svenedin
Jan 28, 2010
1,941
706
Surrey
I received this technical document from Zenith today (4 months after I asked for it but better late than never).
It may be of use to somebody one day as there is next to no information available for this movement. It shows that many parts, but not all, are interchangeable with the 177T. This information is not available in Bestfit catalogues or on Cousins UK.
Bernhard J.
Jan 10, 2022
1,574
1,612
Berlin, Germany
Since I've had the balance out just now should I re-clean the balance jewels and re-oil the endstones? I am reluctant to do this as it involves the dreaded Kif springs! :emoji_laughing:
Oiling endstones in watches with shock protection systems is indeed not really funny for various reasons. First, handling an endstone with an oil drop on it needs specific care when placing it. Second most people tend to overoil at this place. Third, if anything jumps away you start again, including rinse.
I have found most convenient automatic oilers designed for shock protection systems. They place exactly the desired amount of oil on the endstone without the endstone being removed. In practice this means that you fit the clean, but oil-free endstone including the spring system and after assembly use such an oiler. I have found this most convenient also for watches, including pocket watches, without shock protection systems. Mine is called Bergeon 7718-1 and costs around 20.--.
Cheers, Bernhard
Bernhard J.
Jan 10, 2022
1,574
1,612
Berlin, Germany
Ups, indeed, well, indeed some time ago. But even at those costs still worth, at least if there is more than one watch to service every few years.
It works just as well and convenient on other jewels, only in case of pallets I personally stick to my "traditional" oiler needles.
Cheers, Bernhard
svenedin
Jan 28, 2010
1,941
706
Surrey
Thank you for the suggestion Bernhard. I think one of these oilers would be very useful for me. Even without a shock system endstones are tricky and easy to disturb when tightening the screws of the setting (especially the balance cock endstone). I have a 21 jewel pocket watch on my “list” to service and I think I will treat myself to the automatic oiler.
This watch is running beautifully now and is my most accurate pocket watch at the moment. That’s probably because it is freshly serviced but also due to the “modern” innovations in the balance wheel material and hairspring that make this watch less susceptible to temperature variations than my older watches. The ultra-fine regulator and ease of beat setting helps a lot too. Unfortunately, late pocket watches like this are quite rare due to low production numbers. I have this Zenith, another even better Zenith and a similar late Omega.
This Zenith 3841 may have originally had an outer case as well making it effectively "pair cased". I have seen an example that retained the outer case but I never had one for mine.
This is my other “modern” Zenith:https://mb.nawcc.org/threads/zenith-extra-prima-21-jewels-calibre-68.177792/
Chris Radek
Apr 13, 2014
1,291
774
Lincoln, NE, USA
timeguy.com
I also use a 7718-1A for all jewels with caps, shock resistant or not. I paid about USD$100 for mine and would buy it again in a heartbeat.
I also have the 7718 model (is it 5? 2?) made for oiling train jewels and I never use it. I use regular dip oilers, the good ones from Bergeon, under the microscope.
MrRoundel
Dec 28, 2010
2,470
973
While I haven't yet used it, I just picked up what I believe is a new offering by Horotec (At least I hadn't seen it before.). It is an oiler made for Incaflex jewels. It is not an auto oiler, but rather a very fine gauge wire that sticks out of an aluminum holder that is used like a conventional oiler. While it probably isn't as good as the Bergeon automatics, it sells for under $17 American. Part number is: 17.003. I think it may be adequate for my purposes. In the meantime, the Bergeon 7718 1A is on my wish list. Cheers.
MrRoundel
Dec 28, 2010
2,470
973
Well, I just used the Horotec oiler, with its .06mm wire, for the first and second times. First it was to oil through the hole jewel on an Inca jewel in a 6 3/4x8 ligne FHF 64-21 movement. Then I used it to oil the dial side train jewels that are barely accessible under the escape wheel. I did it under a microscope, and got the right amount right where I needed it. So far, so good, FWIW. Cheers.
svenedin
Jan 28, 2010
1,941
706
Surrey
Thanks for feedback MrR
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
Staff online
181,330
1,582,210
54,774
Jim Lampros
3,126
Top
