Hi,
I have a Zenith clock radio C472W the radio works fine but the clock does not. I took her apart & found no broken gears I checked the motor & it does not run but is getting voltage.
The motor is General Time Corporation the gear turns fine when I turn it buy hand.
So I guess it's the motor my Question is does anyone know where I can get one?. Or is there any other Manufactures that use this motor?. I have tried ebay but there is nothing on there as far as the Zenith C472W. I was just wondering if another Manufacture used this motor.
Also the light does not work that lights up the numbers the wires come off the motor. I can put pictures up if that will help Thank you for your help. Will,
