• Upcoming updates
Zaanse pendulum
disciple_dan
Mar 10, 2016
1,793
179
65
Plant City
I have this Zaanse clock with a Hermle 261 in for replacement. The pendulum bob is a loose fit on the leader and will rotate as it goes. How where these fit initially? The leader is threaded but the bob is not and it slides over the threads. I put a nut under it. Did the bob have threads at one time? Thanks, Danny
18,022
3,490
There is usually a flat spring that applies pressure between the pendulum rod and the horse. The horse will still rotate but the friction from the spring will keep it in position, once it's placed in position.
5,732
955
No. As far as I know they all had a nut.
JTD
If the bob was threaded, it would mean that you could regulate up or down only in full turns. That would be a rather coarse regulation.
Reactions: JTD
disciple_dan
Mar 10, 2016
1,793
179
65
Plant City
The spring makes a lot of sense. Since I don't have much I use some of Willie X's. Thanks, Danny
18,022
3,490
Most springs are about 1" wide and about 5/16" wide. It would have a slight bow from end to end with a vertical crease made in the middle. The crease locates the spring left and right. It's made similar to a clock's fly governor but simpler.
49,515
2,940
I've never encountered a horse like yours. Are you sure it wasn't home made by someone? I would only be concerned with the weight though.
5,732
955
The horse is shown from the back side. That makes it look quite crude.
49,515
2,940
178,995
1,570,042
54,043
nrizzo
909
3,088
Swiss Fake by Kent
