Your thoughts, this clock
Discussion in 'General Clock Discussions' started by RJSoftware, Feb 25, 2006.
  2. It's Coming
    Tomorrow
  1. RJSoftware
    RJSoftware Registered User
    Apr 15, 2005
    8,307
    77
    Loxahatchee, Florida
  2. RJSoftware
    Apr 15, 2005
    8,307
    77
  3. DG
    DG Guest
    RJ,
    Looks to be a C.1927 Sessions Clock Co., "Hyannis", 8-day lever movement banjo timepiece. 22.5 inches tall. Looks complete other than perhaps the eagle on top? I don't see it in the eBay pics. The movement probably just needs cleaning.
    Denis
  4. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    152
    deceased
    RJ, there is a dog!! Good deal. Your clock is in Tran's Sessions book. It is the "Province-town, circa 1930, 22 1/2 inches long, 7 1/2 inches wide, Mahogany finish case, with inlay design, 5 inch metal dial, polished brass sash, convex glass, glass panel with attractive marine view in colors, 8 day, time, lever movement, $16.20".
    I guess you will have to learn all about lever escapements and hairsprings and balance wheels. It should have a brass eagle on top, but I don't see it. Everything else looks all right.
    Harold
  5. RJSoftware
    Apr 15, 2005
    8,307
    77
    Hey all thanks for quick replies!
    Alrighty!
    About time I scored a gooden.
    Any chance any of you have a link to lever escapement? Does this mean it does not have pendulum but like balance wheel type?
    RJ
  6. harold bain
    40,850
    152
    deceased
    RJ, yes, no pendulum. Balance wheel. Check the find on repair board for lots of neat stuff about these. Probably does just need a good cleaning, maybe bushings. Time only so a simple movement.
    Harold
  7. newcat
    newcat Guest
    it is an electric clock
  8. DG
    DG Guest
    I don't think so... but I'm always willing to learn :)
    Denis
  9. RJSoftware
    Apr 15, 2005
    8,307
    77
    Thanks Harold. Great info!
    Kinda angular palettes. Wonder why they would do that?
    Sorta looks like it would be touchy. I guess depthing is super critical. As small angles on palettes are only area escape teeth should hit.
    Anyway, I have a feeling I'm gonna like this clock. 8 day is great. Getting tired of them 30 hour winding.
    RJ
  10. newcat
    newcat Guest
    See the red second hand. A trademark hand for sessions electrics and also the description clearly states it is an electric
  11. newcat
    newcat Guest
    As long as the coil is good the motor bearings can always been repacked and movement cleaned.The only possible problem down the road could be the drive gear that meshes with the worm gear. Many of these were fiber and crumble when dry. I usually put an extremely thin layeer of Alemite grease on them to try and keep them moist.
  12. RJSoftware
    Apr 15, 2005
    8,307
    77
    Hey newcat; I see no mention of electrical movement in description. Also has key and one winding arbor hole. Re-check the link above.
    RJ
  13. newcat
    newcat Guest
    RJ
    Duh, you are right! I was looking at those other clocks! The guys are right, balance wheel, pin pallet
  14. RJSoftware
    Apr 15, 2005
    8,307
    77
    No problem. Taker easy.
    RJ
  15. Scottie-TX
    Scottie-TX Registered User
    Apr 6, 2004
    936
    Mesquite, TX
    Hmmmmmmm. "Spray Heads", "Victrola Parts and Records", "X games", "Pennies"? ARJAY: You may want to check with your doctor on your meds.
  16. RJSoftware
    Apr 15, 2005
    8,307
    77
    Scottie;
    Yeah Ive been diagnosed as full blown ebayarsinits.
    I gotta suffer through some withdrawl symptoms. Avoid that confirm button.
    Btw, I think it's kinda fun reviewing other peoples buying habbits too. Sorta like looking through thier dirty underware. Especially when they buy personal hygene things....:biggrin:
    Ahh well, cheap thrills.
    RJ
