Yet another Movement Holder
Discussion in 'Horological Tools' started by AJSBSA, Sep 2, 2014.
  1. AJSBSA
    AJSBSA Registered User
    Nov 24, 2009
    558
    21
    Clockmaker
    Cheshire, UK
    After reading Steven Conover's marvelous book (Tips and Projects) I was inspired to produce this could not find the McMaster Carr item for the ball clamp but luckily Proxxon do something similar for a very reasonable price. The clamp will work on the pillars as well so will be great for round French clocks I am so pleased I will be making another.
  2. Kevin W.
    Kevin W. Registered User
    22,595
    386
    Nice job, well done.
  3. caddwg
    caddwg Registered User
    Jul 4, 2012
    234
    Architect, Engineer
    Costa Mesa, Ca
    Stephen:
    Great idea!
    I have a Proxxon Vise also.................I may try something similar. It has been a pretty versatile vise. Thanks for the tip.
    Regards: Larry
  4. Joe Collins
    Joe Collins Registered User
    Jan 3, 2004
    986
    A Pana Vise base, either model 300 or 305, will also make a good base. The popular auction site has a large supply of them.
    Joe
  5. Karl Burghart
    Karl Burghart Registered User
    Jan 30, 2012
    190
    Ballston Spa, NY
    Sorry to hijack this thread........
    Joe, Your PM box is full. Looking for plans and the kit for you mainspring winder.
    Thanks,
    Karl
  6. cazboy
    cazboy Registered User
    Apr 27, 2006
    1,106
    Retired!
    Prescott Valley, Arizona
    Nicely done! It looks not only beautifully functional, but extremely well made as well.
  7. emhitch
    emhitch Registered User
    Mar 17, 2009
    97
    medical device design engineer
    pittsburgh, pa
    Stephen, your test stand is truly impressive! Very nice. Could you explain the components between the Proxxon vice base and the movement holder clamp? Essentially, what are, and where could I find, the three pieces in between the ball joint of the vice and the movement holder clamp?
  8. AJSBSA
    Nov 24, 2009
    558
    21
    Clockmaker
    Cheshire, UK
    Hi not sure that I can I made all four parts that is true but the main clamp is from a drawing in Steven Conover's marvelous book (Tips and Projects) sorry
  9. AJSBSA
    Nov 24, 2009
    558
    21
    Clockmaker
    Cheshire, UK
    #9 AJSBSA, Oct 5, 2014
    Just started working on a under slung chiming clock which is often one of the most difficult to test and support when building up I am pleased to report this holder holds the movement very firmly.
    and a French Clock
  10. AJSBSA
    Nov 24, 2009
    558
    21
    Clockmaker
    Cheshire, UK
    #10 AJSBSA, Oct 7, 2014
    I repair too many clocks a week get away with just the one holder or even two so I converted my Bergeon holder to use the Proxxon ball joint making it much more stable in the process.
    In the meantime I have started a small batch of clamps here they are ready for machining after the band saw four holders should be enough.
    And of course because of the ball joint they fold down flat when not in use
  11. cazboy
    Apr 27, 2006
    1,106
    Retired!
    Does anyone else foresee a run on those ball parts from Proxxon? :D Hey AJSBSA, any chance you could show some detail closeups of the clamping section? I have machining capabilities and I, for one, would like to see how I could possibly try this as a project for my own. Or...oh yeah, I just re-read your original post...I guess the plans come from Conover's "Tools, Tips & Tricks" book. I don't have that book as yet - gotta get me one!
    ...Doug
  12. AJSBSA
    Nov 24, 2009
    558
    21
    Clockmaker
    Cheshire, UK
    #12 AJSBSA, Nov 21, 2014
    When I first made the holder I also made two more rods for wall clock movements used them for the first today, I designed them to fixed at bottom but allow the actual clamp to rotate 360 degrees this has proved most useful.
  13. AJSBSA
    Nov 24, 2009
    558
    21
    Clockmaker
    Cheshire, UK
    #13 AJSBSA, Jan 18, 2015
    Another configuration that works well it also works with a Cuckoo and with a easy mod it would work when the Cuckoo movement is installed in the case (disregard the huge weights I was experimenting)
    I now think this is an improvement on the original Steve Covoner design
