WW83 Bearings and clean up/paint job
Discussion in 'Horological Tools' started by measuretwice, Dec 28, 2019.
  1. measuretwice
    measuretwice Registered User
    Jul 28, 2019
    36
    15
    Toronto
    I'm fairly new here, and come to watch clocks as a bit of a newb, but with a fairly in depth machining background. An admitted toolaholic, watches and clocks are another reason to acquire more tools. I've got a bunch watchmakers/instruments lathes and just recently added this Boley & Leinen WW83. It came up for sale on the other side of the country, but a daughter was living locally and dutifully picked it up lugged it to a UPS store. I didn't realize how heavy it was when I asked the favour - still owe her for that! It cleaned up nicely and I thought the good members here would like to see some photos.
    The lathe was really well accessorized, 2 slide rests, vertical slide with milling and dividing attachment and the, I imagine, rarish threading attachment with all the gears. It needed a lot of cleaning and a paint job. I've a new respect for artists, its bloody difficult to get a colour how you want from mixing. Everything was disassembled, masked and painting was with an airbrush.
    The spindle bearings seemed dicey and the OEM's on these are deep groove but its a nice upgrade to install super precision angular contact bearings. I splurged for matched ABEC 7 SKF's and made ground bearing spacers. The bearings on the motor and jack shaft were also replaced. Everything seemed in great shape. The last photo is cutting a 40TPI thread.
    The motor and speed control are less than desirable on this lathe imo so I'm just using the motor as a counter shaft (brushes removed). Powered is from a Consew servo motor which is nice - it senses the speed and puts more current into the motor to maintain the speed under load. It also gives very low speeds which are advantageous for threading. The only complaint is controls....reversing is a pita (needed for threading). I hacked the control so I can switch between foot and rheostat controls, but still haven't figured out an easy way to reverse things.
    turning a spacer on a bigger lathe and checking the spacer's fit in the headstock bore
    D.th.munroe and DeweyC like this.
  2. John MacArthur
    Feb 13, 2007
    340
    29
    Slurp slurp drool.....
    Johnny
    measuretwice likes this.
  3. DeweyC
    DeweyC Registered User
    Feb 5, 2007
    2,056
    721
    Watchmaker
    Baltimore
    Fantastic work!
  4. measuretwice
    Jul 28, 2019
    36
    15
    Toronto
    Thanks Gents, it was great find and I feel fortunate to be its current custodian
  5. wefalck
    wefalck Registered User
    Mar 29, 2011
    512
    37
    Geochemist (Consultant)
    Paris
    Having all that in one, presumably original, set with matching numbers, I suppose, is extremely rare. Good find ! I would be curious to know, how you had to pay for it.
    My jealousy is somewhat tempered by the fact that I own a similar set by their erstwhile competitors Lorch, Schmidt & Co. ...
  6. sharukh
    sharukh Registered User
    Oct 10, 2011
    353
    14
    Doctor
    Mumbai, India
    And some more drooling. But seriously, that is a fantastic piece.
    Sharukh.
