WW Lathe Headstock issues
Discussion in 'Watch Repair' started by NewBernWatchmaker, Jun 1, 2018.
  1. NewBernWatchmaker
    NewBernWatchmaker Registered User
    Jun 1, 2018
    26
    New Bern, NC
    I just got my first watchmakers lathe and cleaned it up a bit but I am wondering how to disassemble the headstock or at least remove the collet and tool. Everything is a little stuck from who knows how long of being together. It is unfortunately a rather uncommon make - Reese from Johnstown PA. I managed to get the locknut on the back undone (anyone know if it was always split or someone did this before to get it off?) but I am still not sure the next step to remove the collet.
  2. NewBernWatchmaker
    Jun 1, 2018
    26
    New Bern, NC
    #2 NewBernWatchmaker, Jun 1, 2018
    Update - I got the tool out of the collet so it is now just a collet stuck in place. They just screw in right (Left to loosen?)?
    Update Again - Ah the headstock wheel just spins off the collet, very clever. That was easy enough... So how does the spindle come out?
  3. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    3,406
    94
    Gothenburg
    I have had a lathe where the wheel is split by its design. It is a way of locking the nut in place.
    To remove the spindle on my lathes there are some screws holding the coned center part in place. (Look in the grooves and around the entire wheel. )There might also be a ring with some screws under the brass screw-on piece to the left. When the screws are loosened my spindle can be pulled towards the right.
  4. Jack_W
    Jack_W Registered User
    Mar 8, 2010
    156
    Geologist
    Wheat Ridge, CO
    I'd suggest a copy of Archie Perkin's "Watch Makers Lathe and how to use it". There is a section on the care (disassembly and reassembly) of the lathe head. Perkin's book is much better in this regard than DeCarle's Lathe book.
    Join the NAWCC and borrow Perkin's book from the library (dues plus $7) or buy it from the AWCI for $100. If you are going to own a lathe, you're going to want more than whats on the internet.
  5. NewBernWatchmaker
    Jun 1, 2018
    26
    New Bern, NC
    That one is definitely on my list. All in good time =)
