The NAWCC Museum and Library & Research Center are currently open.
Please check the Visiting Schedule for Days and Hours at the bottom of the Visit Page.
PennwoodWrong Wattage for Pennwood numechron motor
Hi! I have two motors (pennwood numechron) for desktop clock. Wattage indicated as 3,7 W. But when connect ammeter is obtained 50mA, which corresponds to 55W. Why so? Thanks!
...because 120V x 50mA gives 6W, no 55W
...because with inductive loads there is a phase shift between AC voltage and current, and then V x A is different from Watt.
...because a running motor generates his EMF voltage which is subtracted from his supply voltage.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
