Writing articles List example
Discussion in 'Archived Threads' started by Encyclopedia Management, Jul 3, 2009.
  2. Check it out in the NAWCC Events forum:
    Talk about the upcoming National Meeting
    If you love watches or clocks you've got to come!
  1. Encyclopedia Management
    Encyclopedia Management Administrator
    Jul 12, 2009
    173
    #1 Encyclopedia Management, Jul 3, 2009
    [toc]no[/toc]
    Examples of different types of lists.
    Numbered list example:
    The following is a list:
    [list=1]
    [*]List item.
    [*]This list item has 2 paragraphs.
    Just about any text (including codes) can be inserted into a list item.
    [*]And a third item.
    [/list]
    This code produces the following list:
    1. List item.
    2. This list item has 2 paragraphs.
    3. And a third item.
    Lettered list example:
    [list=a]
    [*]List item.
    [/list]
    • List item.
    • This list item has 2 paragraphs.
    • And a third item.
    Bulleted list example:
    [list]
    [*]List item.
    [/list]
    • List item.
    • And a third item.
    Note that the bulleted list is not indented and often you will want to use [indent] with it.
    Other enumerator examples:
    Enumeration sets supported are Arabic (1), lower case Latin (a), upper case Latin (A), lower case Roman (i) and upper case Roman (I). In each of the following lists the first item gives the
    [list]
    code used to generate it:
    • [list=A]
    • Second
    blank line
    • [list=i]
    • Second
    blank line
    • [list=I]
    • Second
    For Arabic number enumeration any number will do, for example
    [list=5]
    produces the same list. All other enumeration selections require the first value in the enumeration set.
    Nested lists:
    Lists can be put inside lists, as in the following example:
    [list=1]
    [*]List item.
    [*]This list item has a list within it.
    [list=a]
    [*]Just about any text (including codes) can be inserted into a list item,
    [*]including[indent]indented text[/indent]as here.
    [/list]
    [/list]
    1. List item.
    2. This list item has a list within it.
      • Just about any text (including codes) can be inserted into a list item,
      • including
        indented text​
        as here.
    Tutorials
