For some time - starting during the COVID lockdown period up until initiating this thread I have returned repeatedly to spend chunks of time on one of my pet projects, trying to solve a little mystery about determining who was the designer of a stopwatch made by Gallet in the 19th century that happened to play a part in a famous milestone in aviation history.
My conclusions to this project is that the designer of this particular stopwatch is a previously unidentified very early Leon Breitling, at the start - or close to the start of his career which eventually progressed to the manufacture of Breitling chronographs recognised worldwide.
Any comments are welcome. I am far from an expert and there are others who may own similar vintage stopwatches who by taking photos or offering insights may be able to add (or take away) clarity to the following research....
To begin...In 1903 there were two virtually identical stopwatches used by the Wright brothers to time the first powered airplane flight at Kitty Hawk, North Carolina. These two stopwatches may well have been made within a year or two of this great historical moment but I think they were designed much earlier and then also manufactured by Gallet at least 13 years earlier.
The stopwatch that was used aboard the Wright Brothers 'Flyer' is on display at the National Air and Space Museum in Washington DC while the other one is located at Gallet HQ in Switzerland.
Link to the Wright Bros stopwatch at the National Air and Space Museum at the Smithsonian:
airandspace.si.edu
Link to the Wright Bros stopwatch held by Gallet HQ, Switzerland:
Gallet identifies these two stopwatches as made by the company. They are described on the FB page on October 30, 2021 as "stopwatches manufactured for Louis Goering by Gallet with Excelsior Park movements"
On the Mikrolisk trade mark index website you can identify a "Solid Electric Plated" variation of the trademark symbol "The Sun" image that is on the inside of the watch case cover as granted to Louis Goering in 1901 who was an importer of Swiss watches into the USA
What is interesting on this attachment is that a previous Solid Nickel Variation of "The Sun" trademark was made in 1883 by an importer Louis Strasburger & Co, which was taken over by the widow of Louis Goering in 1903 (twenty years later)
Around 1890, importer Max Eppenstein (founder of the Illinois Watch Case Company) produced a catalogue which included an advertisement for a Horse Timer "The Sun" for $11.50
So, regardless of whether the stopwatch case was made of "Electric Plated" nickel or "Solid Nickel", the stopwatch design that was used to time the Wright Bros 'Flyer" in 1903 appears to date back to at least 1890.
In July 1891 in The Breeder and Sportsman magazine, a Horse Timer called "The Racer" was advertised:
The following photos show the actual face and the internal mechanism of 'The Racer' Horse Timer which shows that the movement is identical to the Wright Bros "The Sun" stopwatch.
The Wright Bros "The Sun" Flyer stopwatch has a serial number 155813
This "The Racer" Horse Timer has a serial number 152***
The following Horse Timer also has an identical movement (and a glass dust cover) and has a serial number 156***
Another Horse Timer (which doesn't work and doesn't have a glass dust cover) is shown below.
It also has an identical movement to the Wright 'Flyer' stopwatch.
The serial number on this Horse Timer is 153***
Now this is where it gets intriguing....
The following Horse Timer is one called "Jerome Park"
Jerome Park was a horse racing track located in Brooklyn New York that was owned and named after "The King of Wall St" Leonard W Jerome (1817-1891) who was Winston Churchill's grandfather. The Jerome Park racetrack was in operation from 1866 to 1894.
"Jerome Park"is listed under Gallet's stable of pocket watches and on their Gallet World website they have dated a Jerome Park chronograph for the U.S. Navy to 1914 and attribute the movements to Excelsior Park and Minerva.
This Jerome Park Horse Timer movement (which also has a glass dust cover) is a movement patented by Ferdinand Bourquin in 1891.
Ferdinand Bourquin went on to be the founder of the Leonidas Watch Factory before his death in 1905
The serial number of this Jerome Park stopwatch is 151*** and on the movement it has the words "PAT. APLD. FOR" which suggests that the date for the manufacture of this particular stopwatch or Horse Timer is in 1891
Below is the Swiss patent No. 3071 granted on 30th January 1891 to Ferdinand Bourquin
And the US patent No. 458348 granted on 25th August 1891 to Ferdinand Bourquin
This Jerome Park Horse Timer whilst having some similarities to the 4 stopwatch movements mentioned previously, is actually quite different in a number of aspects.
Whilst all five serial numbers are fairly close together - indicating that Gallet was the manufacturer of all five stopwatches, and it is clear that it was Ferdinand Bourquin who designed the "Jerome Park" stopwatch, it still begs the question on whether Ferdinand Bourquin was also the designer of the three previously mentioned Horse Timers that share the identical movement to the Wright Bros "Flyer" stopwatch
None of the stopwatches at this point have trademarks identifying the designers. This is likely because Gallet, being the manufacturer, was probably sourcing the movements from individuals who had not yet built up their businesses into independent companies.
At this point we should view the following advertisement published by leon Breitling in 1894 when he moved from St Imier to Chaux de Fonds...
As you can see, in his 1894 advertisement Leon Breitling has a Horse Timer stopwatch as a display model on the right. The numbers on the minute dial count up to 10 in a clockwise direction.
The following pocket watch movement has the minute dial counting up to 10 in an anti-clockwise direction. Under the plate there is a Leon Breitling trademark (seen on the Mikrolisk trade mark index as granted in 1892) and on the plate it has the Swiss trademark #3823 for his patent (granted in July 1891)
Whilst I can't tell if the above Horse Timer/stopwatch was manufactured specifically in 1892 through to 1898, the following 1898 advertisement has two images that were trademarks granted to Leon Breitling on 13th May, 1896.
The footnote in this 1898 advertisement above is translated below:
The Mikrolisk trade mark index lists these two images as granted to Leon Breitling in 1896 - however his advertisement in 1898 states he had been using the images since 1890 which was before the patent #3823 was granted to him in July 1891. Therefore Breitling must have been using a movement that was possibly of different configuration to the patent #3823 that was granted to him at a later date.
Does this mean that in 1890 Bourquin beat Breitling in a race to have their original patents for Horse Timers approved?
Did Breitling have an earlier patent rejected because it was found to be too similar to the Bourquin design?
Did Breitling have to redesign his Horse Timer in 1891 in order to continue deriving an income from supplying movements to Gallet? Breitling's Swiss patent #3823 was granted six months after Bourquin's Swiss patent #3071
We do know that Gallet in the 19th century was a customer of Breitling's Horse Timers and stopwatches and were beneficiaries of his expertise - Another line of Gallet's stable of pocket watches was the "Trotter" - also a Horse Timer. On their Gallet World website Gallet states their stopwatch "Trotter" was registered pre-1897 but instead of an Excelsior Park movement Gallet used the Breitling Swiss patent #3823 (see photos below).
Stopwatch, Wright brothers
Hand-held stopwatch, nickel plated with white face and black Arabic numerals (increments of 5, 5-60). Smaller inset dial above second hand mount to record minutes (1-10, increments of 1). "The Sun" in black script immediately below second hand mount.
