Woodwork Movement help
Discussion in 'Wood Movement Clocks' started by eculuke, Nov 22, 2014.
  1. eculuke
    eculuke Registered User
    Aug 11, 2014
    133
    Hey guys,
    Sorry to ask so many questions. After a lot of trial and error I did get the movement back together. I am having an issue getting it going. For some odd reason without a weight it seems to run and advance the escape wheel......but there is one problem...it seems to turn the wheel backwards in the wrong direction. I took two videos and posted them on youtube in hopes you guys could offer some suggestions. I have the ability to do slow-mo so for a short part of each video its in slo-mo so you can really get a good look. I thought at first it was out of beat but I have been unable to get it moving in the right direction. Any help of additional videos I can do.
    running , no weights, escapement turning clockwise
    http://youtu.be/HfDpLSBtYvs
    Not running, with weights, attempting to go counter clockwise
    http://youtu.be/ql31Eoduu0o
  2. Kevin W.
    Kevin W. Registered User
    22,454
    369
    I am not a expert on wood movements. But did you do any bushing work, did you check for wear in the holes the pivots run in. I am thinking a lack of power is causing this. Hope others with more knowledge will see your posting.
  3. Peter A. Nunes
    Peter A. Nunes Moderator
    NAWCC Fellow NAWCC Member Sponsor
    Mar 3, 2006
    1,655
    Restorer of antique clocks.
    Rhode Island
    Well, the escape wheel is indeed going backwards. Have you installed the strike side great wheel and winding drum on the time side? I wouldn't think it would fit, but it would explain the reverse running.
  4. R. Croswell
    R. Croswell Registered User
    10,333
    867
    Is confusing having the same thread here and also in clock repair and some answers here and some there. Perhaps the two can be merged into a single thread that is easier to follow?
  5. eculuke
    Aug 11, 2014
    133
    I wasnt getting many responses in wood works so I tried repair section since it falls in both
  6. R. Croswell
    10,333
    867
    Yeah, I know what you mean. Not a lot of action here, but this IS the place to look the for people that have the most experience with wooden clocks (not speaking of myself). I collect and work on both brass and wooden clocks but really like the wooden ones best, but there are a lot more brass clocks and people that are only or mostly interested in that type.
  7. Standard time
    Standard time Registered User
    Nov 17, 2012
    10
    your winding arbors/drums are switched..The left side winds to the right ( counterclockwise) while the right side winds to the left ( clock wise) Take it apart and switch those two gears and it will work fine.
  8. R. Croswell
    10,333
    867
    Yeah, that was my initial thought to but check this link https://mb.nawcc.org/showthread.php?118889-Movement-help/page2 the same question was posted in "Clock Repair" and is up to 19 responses. The winding drums were not reversed and the problem was apparently a substituted verge that was incorrect. The OP installed a different verge and it ran ok. and it goes on from there. Is really confusing when someone posts in two forums and the replies are only posted in one so its easy to miss part of the story.
