Woodwork clock question
Discussion in 'Wood Movement Clocks' started by tlw1344, Aug 4, 2014.
  1. tlw1344
    tlw1344 Registered User
    Apr 30, 2007
    353
    Central Alabama
    I was given a woodwork clock that would not run. It mounts on the wall and has two weights...it has a bell on the top for striking the hour. I do not have any experience in woodwork clocks. It is very dirty and need cleaning first. Not sure how to take the plates apart. What do I use to clean the wood? Any suggestions would be helpful. I want to fix it and put it in my house.
  2. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    9,930
    212
    Industry Specialist
    Launceston Tasmania
    #2 leeinv66, Aug 4, 2014
    Read post No:5 in THIS THREAD for some information on the movement you have. You need to pull the nails out of the top of the middle posts at the front and back to remove the wheels with this fore/aft train configuration.
  3. tlw1344
    Apr 30, 2007
    353
    Central Alabama
    What should I use to clean the wood? Should I put the gears in my ultra cleaner?
  4. shutterbug
    43,162
    1,182
    #4 shutterbug, Aug 5, 2014
    I'd try one of the standard wood cleaning products for antiques. The gears can go into the ultrasonic, no problem. It doesn't look like the movement has ever been bushed. It's possible that the wood holes have worn out by now. If so, consider a bushing made of bone (or ivory if you can find it). Otherwise, a wooden plug, drilled and burnished would be a good choice.
  5. Jim Duncan
    Jim Duncan Registered User
    May 31, 2011
    417
    10
    Central Coast of California
    For cleaning wood you might consider Murphy's Oil Soap available in most hardware stores and in use for decades. Not caustic and not that expensive either.
    Jim
  6. tlw1344
    Apr 30, 2007
    353
    Central Alabama
    I have one pivot that looks like a needle. Must put a new pivot on this wheel. This means I will need to put a new bushing for the new pivot. Not sure how to put the new pivot in the wood. Do I put a bushing in like it is a brass plate? What will hold the bushing in place?
  7. R. Croswell
    R. Croswell Registered User
    10,209
    821
    Generally, one would use a little glue to hold wood bushings. Not sure that I would do any cleaning other than brushing and wipe with a cloth.
  8. eskmill
    eskmill Registered User
    NAWCC Fellow NAWCC Member
    Aug 24, 2000
    7,135
    Fortunately the Black Forest wood posted movement shown in thw's photos has wheel arbors made with wooden spindles thereby replacing severely worn pivots relatively simple provided the pivot wire is not rusted in the spindle.
    Bushings for these clocks are originally made from flat brass strip rolled into a tubular shape with a short sharp edge looking somewhat like the letter Q. The tang or sharp edge secures the bushing in the wooden plate hole.
    These bushings are relatively long, almost the width of the plate hole. Brass round stock can be turned into usable long tubular bushings and pressed into the plate hole.
  9. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    9,930
    212
    Industry Specialist
    Launceston Tasmania
    Sorry I am late replying, but I lost track of this thread. But God no!!!!! What ever you do, don't put these wheels in an ultrasonic. The wheels are held on the wooden arbors with wooden collets. You don't want any part of these getting soaking wet, let alone vibrated to pieces. A damp cloth and a small hand held wire brush is all I would use to clean it.
  10. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    9,930
    212
    Industry Specialist
    Launceston Tasmania
    Do you mean the steel pivot is slightly cone shaped? If so, that's how they made them.
  11. tlw1344
    Apr 30, 2007
    353
    Central Alabama
    Yes, it is very small. It is cone shaped to a pin point. No other pivots are like this one. It is on the second wheel. Would you know the date of this clock? I have a book that states that many wood works clock were made 1800 to 1840. Does these come with rope or chain. The sprocket teeth are pointed therefore I'm thinking a rope was original. What width would the rope be? Would you go to the width of the sprocket? What type of rope is original?
    Thanks.
  12. shutterbug
    43,162
    1,182
    These look like brass and brass, Peter :)
  13. eskmill
    Aug 24, 2000
    7,135
    No Shutterbug. The wheels are cast brass fixed onto wooden hubs or spindles. (Holtzgespindlen ?)
    They have many close fitted parts to support the brass wheel and glued in place. The pivots are pressed into the spindle. Most of the wood spindled BF clocks have the wood painted with aluminium paint to resemble polished steel. On some, the vertical pillars have thin brass strips to resemble a brass plated clock.
    I have brightened the wheels in thw's photos to reveal the wood spindles.
  14. bangster
    bangster Moderator
    19,697
    407
    I'm moving this to the Wooden Works forum.
    bangster
    moderator
