Wooden Works
rfh11
Dec 13, 2008
132
Hello to all,
I recently purchased a Austin Chiddendan wood works clock. The works are in great shape but I am starting to wonder if the works are original. I looked through 1980 NAWCC bulletin and none of the works are even close to what is in the clock. I know you guys want a picture and I will post one. My question is who or what was the application for works that have the verge between the plates. My guess is these works were for a tall case clock. Waiting for your replies.
Thanks,
Randy
Dave B
Banned
Jun 7, 2008
2,389
Westminster. MD
Many New England and New York clockmakers made clocks with the ecsape wheel between the plates. That is a common feature. The giveaway as to the case it belongs in would be the length of pendulum required, and the distance the weights would have to fall to give full running. Distance of weight travel can be readily calculated by the dimensions of the time side barrel and lines. The width of the barrel and the thickness of the line will determine the possible number of turns on the barrel circumference. A rough approximation of the pandulum length can be computed by counting the teeth on the wheels and leaves on the pinions from the minute wheel through the train to the escape wheel. , and knowing that there are 3600 seconds per hour and a one second pendulum is nominally a yard long.
Most wooden movement clocks in colonial US were sold without cases, the customer having a case made locally.
Andy Dervan
Gibbs Literary Award
NAWCC Star Fellow
Oct 23, 2002
2,835
109
Hello Dave,
His name is Austin Chittenden and John Burr he were in business together in Lexington, MA from 1831 to 1837. They were not true "clockmakers", but rather assemblers purchasing movements from different Connecticut clockmakers and assembling clocks. They might have even purchased both movements & cases....
It would be helpful to have photographs of movement - front view, back view, and side views to identify probable movement maker.
Andy Dervan
Jerome collector
Sep 4, 2005
894
102
Omaha, NE
Randy,
If I had to guess you have a Chauncey Boardman overhead striking groaner-style movement. I used to own an Austin Chittenden clock with a groaner. If memory serves, Boardman and then Boardman & Wells were known suppliers of movements to Chittenden (in business for himself and also with partner Burr). It would help to see a photo of the clock and movement, but I haven't heard anything that makes me concerned about the originality of the movement.
Mike
rfh11
Dec 13, 2008
132
Thanks guy's for the information. After I spent a little more time looking at the clock. I have no reason to believe it is not the correct works. Thanks again.
ismax
New Member
Jan 6, 2010
Hello everyone i from Russia and i also have clock German's clock Brandmann, Berlin C 25, Munzstrasse 26
This clock was move in Russia after Wold War II.
165,503
1,440,715
86,271
HamiltonFan
2,873
