Wooden works weights
Bob Reichel
NAWCC Star Fellow
Feb 13, 2001
976
Need to know the proper weight of weights for a DANIEL PRATT, JR, 30-hour, 33 inch tall, two door Empire case, with Boardman & Wells wood movement. The clock was purchased out of state and was shipped quite disassembled with 35 oz. weights. These weights appear far too small. Substitute weights in the range of 58 oz. are now allowing movement operation.
Scottie-TX
Apr 6, 2004
936
61
80
Mesquite, TX
Certainly I don't know "proper" for this clock but less than 4#? Sounds like ya pretty much nailed it. We'll await PROPER tho.
14,113
1,517
Bob,
Something between 2 and 3 pounds will usually work. Often the strike will require less weight than the going, to give you a (not to fast) roll. The weight requirement varies quite a bit, depending on the general condition of the movement.
ballistarius
Oct 26, 2009
836
30
Bilbao, Basque Country
I bought a Boardman & Wells movemnt with original weights and that for the going train weights as much as 3 lbs. 9 oz.
Now I have to replace the missing weights for a Pillar & Scroll and I need advice:
Should I buy the 3 lbs ones or the 4 1/4 lbs. ones from Timesavers?:confused:
Another thing, has anybody tried animal gut for the cords? Which size (diameter) would be the most adequate?
Thanks,
Aitor
Scottie-TX
Apr 6, 2004
936
61
80
Mesquite, TX
Me; I'd test and determine the reliable amount of weight with decent overswing before making any choices. Neither may work.
ballistarius
Oct 26, 2009
836
30
Thanks Scottie:cool:
The problem is that it will take a lot of time before I take that movement apart and replace lots of broken teeth on the strike train...
I just wanted to buy all needed spares beforehand, but I suppose that I could wait longer...;)
I've heard that Groaners need heavier weights, is that true? Is it the same for Jerome's thins?
Aitor
harold bain
40,853
178
72
Aitor, one reason I would not use either gut or metal cable on a shelf clock is it's tendancy to "birdsnest" if you remove the weight. Cord doesn't do this. Also, I don't believe either would have been used originally.
ballistarius
Oct 26, 2009
836
30
Hi Harold,
Yes, I understand what you mean. Currently, I've got a shortdrop movement by Riley Whiting on my desk and I can't see the moment of taking those brass cables away from their drums, because they are constantly coiling and disturbing everything (I don't want to wind tham again around the drumsto remind me of them...:rolleyes:)
I got the idea of catgut from John Tope. Clearly, braided nylon is not the original material. What was used in nineteenth century?
Aitor
harold bain
40,853
178
72
I don't know that I have ever seen what I would consider original material, but I suspect a string of some kind would have been used, and replaced when it deteriorated. You will often find a hook of some kind at the bottom of the clock, so you can use an elastic band (don't these things have lots of uses?) to keep the cord tight with the weight off. But I don't think this was original to the clock.
ballistarius
Oct 26, 2009
836
30
Sooth,
Do you mean the square weights lited on Timesavers as 'Groaner weights'?
I supposed all shelf woodworks' weights were 'round'...:confused:
Aitor
Sooth
Feb 19, 2005
3,952
72
37
Cornwall, Ontario, Canada
www.angelfire.com
Aitor:
It's my understanding that ALL wooden works clocks used square "Groaner" type weights. I see a lot on eBay and other places with typical round ogee weights, but these are not necessarily correct. Wooden works clocks will run with either style weight (around 3-4lbs). I could be wrong, though.
ballistarius
Oct 26, 2009
836
30
Sooth,
I am a newby with American woodworks, but Mi Pillar & Scroll case shows wear on bakc panel and label only consistent with the rubbing made by cylindrical weights.:)
Aitor
166,352
1,449,407
86,827
kawasemi
2,911
NAWCC Forums Rules by Steven Thornberry
