Hello,
I am completely new to clock making.
I am trying to calculate the dimensions for wheel, teeth, pallets, drop, angles, radii etc of the Graham dead-beat.
I have consulted several sources and not two of them agree on the method. I would appreciate it if you could help me with a tried and tested method or if there is any industry standard, could you please tell me what it is?
I used the calculations from The clock Repairer's Handbook too (after Abbeyclock, Drawing Escapements and the BHI instructions manual), but the number of teeth I get is 26.25 for my train, though the book does not say whether the formula is for trains with BCTE trains or trains with a F wheel too. I made both calculations based on 3600 bph and none of the results gives 30 teeth which I think should be the right number for the Pendulum to move the pallets 60 times a minute.
I have seen instructions for the drop from 0.5° up to 1°, all of them considering the same 2° swing per beat and the same 3600 bph pendulum. It does not make sense TO ME. Can someone please point me in the right direction here?
Thank you a lot for your help and patience.
