Wood veneer help
Discussion in 'Clock Case Restoration and Repair' started by darticus, May 4, 2012.
  1. darticus
    darticus Registered User
    Apr 14, 2012
    461
    DELI OWNER
    SPARTA, NEW JERSEY
    I have an old Jerome steeple clock. Some veneer is peeling in places. What would be the best way to proceed? I have done some veneer before. SEE PIC. Thanks Ron
  2. Scottie-TX
    Scottie-TX Registered User
    Donor Sponsor
    Apr 6, 2004
    938
    12
    Mesquite, TX
    Tedious we know but first determine specie of wood. Rosewood was very common to many of these. I soak the veneer in a glycerine and water solution for perhaps one day. Then I wrap it around a piece of wooden dowel or brass stock close to the radius of the damage. Let it dry for several days, remove from dowel, and apply. If area is large - replace it entirely. Patching small areas is of course the most challenging if you're trying to match existing veneer. G'luck matey.
  3. darticus
    Apr 14, 2012
    461
    DELI OWNER
    SPARTA, NEW JERSEY
    FANTASTIC! Have you ever tried peel n stick or the flexible veneer? Is it hard to remove old veneer? Thanks Ron
  4. darticus
    Apr 14, 2012
    461
    DELI OWNER
    SPARTA, NEW JERSEY
    Maybe a peel and stick or a flexible veneer is the way to go? Maybe a good winter project. Is it hard to do the round edge of a clock like mine? How would be the best way to try and remove the veneer that on the edges? Thanks Ron
  5. Scottie-TX
    Donor Sponsor
    Apr 6, 2004
    938
    12
    Mesquite, TX
    I have used PSA veneer. (Pressure Sensitive Adhesive) It is CRAPP. I've had disastrous results even on totally flat surfaces. For radius - curved apps. I use only wood glue like Elmers. Apply glue to both surfaces and clamp any way you choose. For your steeple I'd use clear shipping tape. Protect veneer with an isolation barrier of plain paper and wrap with tape.
    Removing old veneer can be either a breeze or a tedious process depending on existing bond.
  6. Patch
    Patch Registered User
    May 11, 2010
    445
    Scottie: Thanks for the advice on the PSA! You just saved me a bunch of heartache!
  7. darticus
    Apr 14, 2012
    461
    DELI OWNER
    SPARTA, NEW JERSEY
    Are you saying use the packing tape to remove the old veneer? Than use elmer's glue to put on new veneer? Thanks Ron
  8. Scottie-TX
    Donor Sponsor
    Apr 6, 2004
    938
    12
    Mesquite, TX
    No. I'm suggesting use of packing tape as a gluing clamp. Make CERTAIN veneer is properly positioned. A paper barrier prevents the adhesive from contacting the veneer. Wrap firmly and allow to dry for a few days.
Similar Threads - Wood veneer help Forum Date
Decorative wood molding???? Clock Case Restoration and Repair Apr 24, 2017
How to clean a black enameled wood clock Clock Case Restoration and Repair Apr 18, 2017
Metamec mantle clock wood preservation Clock Case Restoration and Repair Oct 20, 2016
Bending Veneer and/or wood with steam for Case restoration Clock Case Restoration and Repair Aug 28, 2012
Wood, veneer, and finish identification Clock Case Restoration and Repair May 13, 2011
