Wood Repair to !8th century Longcase clock
Discussion in 'Case Construction, Repair & Restoration' started by ChrisCam, May 9, 2019.
  1. ChrisCam
    ChrisCam Registered User
    Dec 9, 2017
    1,377
    27
    England
    Hi I have repaired some damaged wood to an 18th century longcase clock (my clock by the way). The repair involved. I have used wood die to achieve a near perfect colour match to the old dark mahogany. Question is do I finish these smallish pieces first with clear lacquer or just polish? I would be enclined to just beeswax but hey thats why I am posting?
    Regards
    Chris
  2. Joseph Bautsch
    Dec 9, 2006
    1,113
    124
    Atlanta, GA
    I would expect a 18th century wood clock case to be finished in shellac. I would never use a lacquer. Test to see if that is a shellac finish by taking a white cotton cloth wet it with alcohol and rub the finish in a non-conspicuous place. If some of the finish rubs off on the rag then its shellac. If it is the retouching you want to do is easy. Apply a light coat (not more than a one pound cut) to the area needing repair, feathering out the edges. You can use steel wool to flaten out the shellac if needed. Apply more coats if needed. Then finish by cleaning the case and apply a coat of wax. A beeswax polish would be a good choice.
  3. ChrisCam
    Dec 9, 2017
    1,377
    27
    England
    Thank you Joseph.
    Chris
  4. Uhralt
    Uhralt Registered User
    4,731
    548
    Shellac is wonderful! Search for shellac on this forum. you will find a lot of useful information of how to use it. One coat is usually not sufficient. If the result is too shiny you can use 0000 steel wool to flatten it a bit , followed by wax.
  5. ChrisCam
    Dec 9, 2017
    1,377
    27
    England
    Thanks that's useful
    Chris
