Wood Movement Quail Cuckoo (PHS ?) Original parts ?
fairchild
New User
Sep 5, 2022
Should this be in another forum ?
Not really a wood movement only a wood Frame
Good Morning to you all :)
Recently started cleaning up/out parents home. Found 3 barrels full of old Cuckoo clocks
This one being of interest to me since it looks to be an early PHS movement ?
Question is do you all think this is the correct case top with the Quail ? Looks to match
the rest of the case as far as carving, detail and Color ?
Also dont think the pendulum is correct, need to research what the original would of looked
like since I have many extra parts to look through (3 barrels full)
Reading up on these forums I have found DATING these Wood Frame Movements are difficult.
Although I have noticed a few details that may help
No 1 is the Wooden Perch Bird bracket, have read the Early clocks used the Wooden perch mount for the bird?
No. 2 is the spring hold down used on the chime wheel (not sure what it really is called) Others I have seen
use a tapper pin to hold and assume this spring type hold down is an early process since the Tapered pin
would be much easier and cost effective
No 3 is the Hand shaft that is nailed to the wood case.
Any help or comments are more than welcome. I am a novice at this, Dad was the clock guy.Anyway Wish me luck. Figured since it was not working I would attempt a clean up and rebuild As you can see I already took the movement apart and now waiting for polish wheels to finish up the clean up and re-assemble.
BTW There were 23 cuckoo clocks in the 3 barrels
new2clocks
Apr 25, 2005
4,576
931
Pennsylvania
Welcome to the forum.
It is a wood movement and is in the proper forum.
Why do you say that it looks like an early PHS movement?
Yes, they are difficult.
Can you provide a picture of the front of the movement before it was disassembled?
Regards.
Reactions: fairchild
fairchild
New User
Sep 5, 2022
Thanks for the kind Welcome. much appreciated
Oh that was just my Assumption :) Very Much a Novice.
I assumed it was a PHS Movement (no markings or label) The spring
hold down on the chime wheel ? I have noticed on other PHS movements
but other than that no clue :)
As to being an early movement I again concluded this by looking at
the perch mount used for the Bird, Also read this type of mounting
was used on early cuckoo clocks.
I have never repaired or worked on a clock, this is my first attempt of
any kind of movement. Seemed rather simple so figured what the heck/
Regards.
Sure I took detailed photos from all sides and angles to help with the re-assemble
new2clocks
Apr 25, 2005
4,576
931
Pennsylvania
View attachment 724855 View attachment 724856 View attachment 724857
Philipp Haas & Söhne used a hare as a trademark from 1883 and they made wood movement clocks until 1910.
Your movement could be a PHS movement without the trademark, but I am not sure.
I do not believe it is as late as 1910. My guess would be the 1880s. Others may have different opinions to the vintage of your clock.
Regards.
fairchild
New User
Sep 5, 2022
OK Putting the Strike train back together and wanted to point out what I ASSUME
is the TIMING MARK/LINE to set
Put a couple Levers in and so far it seems to be working correctly
Once I have the levers in I can check to see how close I got the timing :)
The Timing I assume is set with any of the lower Pins lined up with the above
dark scribe line, Additionally the other gears must be set at the start of the ring/chime
NOTE the gear on the left is 180 deg off position.
BTW Thats a tooth pick pointing to the center of the allignment
177,715
1,557,625
53,661
sara.fagan73
909
3,061
