Dennism
- Jun 4, 2013
- 46
- 2
- 8
- Country
Hi all wood movement guys, I have a problem with a terry style movement. It is installed in a case that I made from a George Bruno plan. The movement runs and I can get in beat with no problem. Approx every 60-90 seconds it sounds as if the escape wheel is skipping a tooth. Sometimes two or three times a few seconds apart then returns to normal. As you can see, it has been rebuilt sometime in the past with brass bushings. I have taken it apart twice looking for anything that is binding..cant see anything.
I am pretty good at making repairs to this type movement but I just don't understand the geometry of this escapement well enough to monkey with it without guidance. Suggestions please. Thanks, Dennis
e.
e.
