Woman gave a Ridgeway Model 152 "Louise" grandmother clock to me.
Discussion in 'General Clock Discussions' started by Robert Gift, Mar 15, 2017.
  1. Robert Gift
    Robert Gift Registered User
    Nov 12, 2012
    184
    Tree service "Branch Manager". Medical courier
    Denver, Colorado
    Originally delivered to an Arkansas address March 29, 1979
    Clean and in good condition. Has not run since they moved 10 years ago.
    Is Louise's movement the same as #304 Diana's "EH"? Wood shaft pendulum looks the same.
    Found the Westminster Chime chain in the base and strung it back on its cogged wheel.
    Is there a stop ring to prevent the chain from running off?
    Adjusted the beat and clock is now ticking perfectly evenly.
    Will oil when I have time. WOULD MOBIL1 FULL SYNTHETIC AUTOMOTIVE OIL WORK?
    Chime rods are not being evenly struck and a few are vibrating against each other.
    Are they carefully bent to not touch or are the chime block screws turned?
    Should the brass name plate be heated with a hair dryer to remove withe least damage to the finish?
    Thank you.
    (Will photo and try to post the Ridgeway color pamphlet showing their many clocks.)
  2. chimeclockfan
    chimeclockfan Registered User
    Dec 21, 2006
    3,349
    13
    Chime rod sets for antique clocks - please inquire
    WI
    The chime rods are usually adjusted at the factory so they don't hit each other or the case. Rarely, if ever, are the chime rod block's threaded screw holes in perfect alignment. If the rods are bent and clattering against each other, you may have luck just bending them back in line however this can run the risk of the rod going flat and eventually breaking off. Give it a try and see what happens.
  3. Time After Time
    Feb 22, 2010
    3,104
    11
    Retired General Dentist
    #3 Time After Time, Mar 15, 2017
    If the clock has been sitting around for a decade, I wouldn't run it at all until you've lubricated it. If there are signs of rust or black deposits around any of the pivots (and the clock has value) I would consider having it serviced. I'm not familiar with these clocks but its movement may be replaceable if it gets too worn out. Recycling a movement with a factory fresh replacement is an option to consider.
    I do like Mobil 1 Synthetic, but you'll get a lot of opinions on oil and discussions on it will sometimes generate a lot of friction. There has been so much discussion as a matter of fact that the Message Board Search engine will return too many hits to go through in one evening. Some folks don't use anything other than clock oil on clocks. You can seldom go wrong in doing so. See: http://mb.nawcc.org/showthread.php?114644-Oil-a-clock-How-To if you have any questions on how to oil a clock.
    Here's a brief article written by Stephen Nelson. He uses quality synthetic motor oil in servicing Vienna Regulators: http://www.snclocks.com/TechnicalInformation/Tid-Bits/Tid-Bit-22-Oil-Oilers-Sinks/i-nsJw325 I would suggest a quality synthetic 0-40 high up in the gear trains and a higher viscosity (10-40) on the main and second wheels.
    I've used hair dryers to good effect for removing adhesive from smooth automotive finishes. I imagine that it would work on finished wood but i haven't tried it. If it doesn't come off easily, though, I wouldn't force it. Good luck with the Chime Rods.
  4. Robert Gift
    Nov 12, 2012
    184
    Denver, Colorado
    Thank you. The pendulum and weights, still wrapped in paper in the case behind the chains, may have slid into the rods during moving.
    Will try turning the threaded rod caps. If tight, will deflect the rods just enough to clear. The Westminster B-natural is slightly flat so will tune it.
    Need to find the Dremnel tool to grind the rod end. Filing takes too long.
  5. Robert Gift
    Nov 12, 2012
    184
    Denver, Colorado
    Thank you for the links.
    Neatly scratched on the back of movement: 3-89
    Seems I can never get to a clock shop while they are open. Had an opportunity on Monday and they were closed. Another on Friday and that clock shop was closed!
    We use Mobil1 0W-20 in the emergencyehicles, so hopefully that would be better than nothing - better than the Remington firearms REM Oil with teflon.
  6. harold bain
    Donor NAWCC Member
    39,950
    You will need an impact screwdriver to loosen the chime rod screws. Anything else will just frustrate you. If you bend the rods, do it close to the chime block.
  7. Dave T
    Dave T Registered User
    Donor NAWCC Member
    Dec 8, 2011
    1,528
    retired accountant
    NC
    I had pretty good luck Harold, just using a very large heavy duty screwdriver with a bit that fully fit the slot.
  8. harold bain
    Donor NAWCC Member
    39,950
    You've been lucky Dave. Usually a screwdriver will just break the slot.
  9. Robert Gift
    Nov 12, 2012
    184
    Denver, Colorado
    Yes, very tight. Almost gave up on removing it and would tune attached to the block. Did they use Loctite® ?
  10. chimeclockfan
    Dec 21, 2006
    3,349
    13
    WI
    The rod threads are sometimes "glued" in with hardening grease so they are extra tight fit when fixed into the block. I find superglue is a good alternative when fixing new rods. Other rod threads are tight enough to hold on their own and require no more than just screwing them in as far as they'll go.
  11. Time After Time
    Feb 22, 2010
    3,104
    11
    Pretty low viscosity especially for a Tall Case Movement, in my opinion, but definitely better than nothing. Perhaps even a superior "penetrating' oil for use in a long idle movement. If you go out and purchase some, though, I would get the higher viscosity. You'll have LOTS left over but it's relatively inexpensive compared to most clock oils and it can come in handy around the house.
    You obviously have a pretty good ear for pitch. You must wear ear plugs around all those sirens. ;) Enjoy the presence of your Ridgeway. I do love the Tall Cases.
  12. JTD
    JTD Registered User
    Sep 27, 2005
    3,950
    19
    As long as by asking for 'penetrating' oil, the OP doesn't end up with WD40. That would be very unfortunate.
    JTD
  13. Time After Time
    Feb 22, 2010
    3,104
    11
    Thanks JTD. Yep, we don't want to go there. That would not be good. To be clear, I was referring to the Mobil 1 0W-20 that the OP cited as having on hand. Something about using it in emergency vehicles and it being better than nothing, to which I agreed (although I think that viscosity is a little low for the Grandfather Movements I've seen and worked with)
Similar Threads - Woman gave Ridgeway Forum Date
grandfather Ridgeway clock General Clock Discussions Sep 13, 2017
Woman punches huge English time clock in Faraday Building trunk exchange, London. General Clock Discussions Aug 12, 2017
Dating a Ridgeway Grandfather Clock & info on the pendulum? General Clock Discussions Jun 10, 2017
Want to know what you can tell me on my ridgeway clock General Clock Discussions May 1, 2017
Grandfather clock gave to me General Clock Discussions Mar 17, 2016
