This is my William Upjohn fusee verge. The movement is hinged at 12 o'clock in a gilt case of about 47 mm diameter, there are no case hallmarks. The case has a bullseye crystal. It has a steel three arm balance and Tompion regulator. Movement is marked Wm. Upjohn, Exeter, and with serial number 773.
It has been serviced and works well, about 5 - 10 minutes slow after 24 hours.
I am trying to determine age of this watch, and I am very new to verges so I am hoping for some help. There are two William Upjohn (Exeter) mentioned in Loomes: William I who died in 1768, and his son William II born 1754 and active 1775 to 1803. I believe William II is the most likely watchmaker behind this? And if so, do anyone know his output, so that I may see when number 773 might have been made?
Erik_H
Erik_H
