WM. L. Gilbert movement (1910+?)
Discussion in 'Clock Repair' started by Mario O HONL, Sep 15, 2020 at 2:38 AM.
  1. Mario O HONL
    Mario O HONL New Member
    Jun 29, 2020
    Hello,
    Well, as a novice I have following challenging task for all masters:
    Q: Am I correct that on the included pic of WM.L. Gilbert clock's movement is something missing (e.g. pendulum spring...)? Thanks for help and cheers, Mario (senior with a brand new hobby)
  2. JTD
    JTD Registered User
    Sep 27, 2005
    7,801
    541
    Welcome to the board.
    The suspension spring is the top part of the pendulum rod, which you show lying next to the clock. It attaches to the top bracket (in slit between the two chops) and the rod passes down through the little loop at the bottom. Then you hang the bob on the hook.
    JTD
  3. shutterbug
    43,732
    1,280
    It should have a dimple on the spring, or a small hole where a wire can be inserted to keep it in place. It also should be straight. If it has broken, you can get replacements at most of the regular suppliers. leeinv66 would be able to tell you who the best supplier for your area would be.
  4. Mario O HONL
    Jun 29, 2020
    Hi,
    Thanks to all of you who responded to my enquiry, well done. I certainly hope that after my knowledge build-up, I'll will be also able to help others. Cheers, Mario:)
