I have just finished going through a 1930 Revere model 602 hour strike clock.
I am going to reuse the original power connector junction block, used between the 110 volt input and the field coil. It uses 4 set screws, 2 between the 110 volt supply and 2 for the field coil. The set screws hold each wire into the junction block.
My question is, should the wire ends be soldered, or twisted and left bare?
Thank you.
Thank you.
