Windles Clock Oil?
Hogshair
Sep 6, 2014
106
Afternoon all.
As it's time to replace one of my two clock oils (my Horoloex type 'F' medium watch and clock oil is all but finished) I was wondering what your thoughts on Windles Clock Oil were? Seen it recommended on a couple of forums and Cousins has it at £6.95. Work mostly on french mantel clocks and any carriage clocks that don't cost an arm and a leg!
All the best
Hogs.
18,662
3,984
It's a light oil and good for most clocks.
For me, it's a little thin for the larger pivots near the bottom of larger clock movements.
My 2, Willie X
TEACLOCKS
Mar 22, 2005
3,204
238
73
Santa Rosa Calif.
www.weserviceallclocks.com
Look
  • Clock-Oils[1].pdf
Hogshair
Sep 6, 2014
106
Hi guys,
thanks for the info, much appreciated.
The clock oils pdf is a gem! Read it over and over.
Apologies for late reply. Life got in the way for a couple of days.
Hogs.
R. Croswell
12,678
2,482
www.greenfieldclockshop.com
Hi guys,
Hogs.
There have been several similar reports on oils for clocks. Some, like this one, are mostly anecdotal observations. Others get highly technical and theoretical about principals of lubrication that may or may not transfer to the needs of the clock world. In my opinion, the final chapter is yet to be written. When reading such a report one needs to question whether the author is attempting to validate his own choice, or whether there is adequate scientific research and a large enough sample population to drawl a valid unbiased conclusion.
I have no opinion about Windles Clock Oil (and some of the others in the report) because I've never used it. It has been around for a while and more importantly I haven't heard anything bad about it.
We heard a lot of hype about nano oil, then reports of problems and finally a large movement maker that briefly adopted it suddenly stopped using it. Now we know to avoid it. The report mentioned one brand that turned pivots green, I found the same thing and I believe one would do well to avoid that. We often hear that someone has had great results with a particular oil today, but will they still be excited 10 years later? Is there something better than what you are using, probably, but what will it turn out to be.
The popular consensus is that synthetic oils are preferable, and there is some disagreement about the best viscosity for various size pivots, and whether synthetic engine oils are an adequate or possibly superior substitute for products labeled as "clock oil". I would say the jury is still out on that one. I do not believe that engine oils contain anything harmful to clocks and the anti-wear and anti-friction additive packages may be beneficial. I've often wondered is synthetic oil for reciprocating air compressors might be more appropriate. These machines are like internal combustion engines without the combustion.
For the cautious, I suggest a synthetic oil of appropriate viscosity labeled as clock oil by a well know brand. I use Nye-140 for small pivots and Mobil-1 (zero)W-20 for average to large pivots. I like Modil-1 75W-90 gear oil for mainsprings and have encountered no problems. I find it helpful to hear what others have found to work or not work.
Mike Mall
Oct 27, 2021
558
222
When I first heard of using whale oil, and other fish oils on clocks, I thought it was a joke.
Turns out it has very good resistance to oxidation, and worked well. (sadly)
The evolution of clock oil is very interesting, as it goes back way further than automotive oils.
Someone recently stated here that oil preferences, and other aspects of clock repair, become almost theological.
Understatement? :chuckling:
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
181,317
1,582,077
54,765
Hec Losame
3,126
Top
