I hope you can see this clearly enough. As I was putting these stops on with the movement installed, I couldn't figure out how to make the stops the same number of teeth away from the long tooth so they will stop at even heights. As you might be able to see the strike stop is 4 teeth frim the long one, the Time is 3 away and the chime is 5 away. The weights are all even now but I don't think they will stop at the same height when I remove the shipping blocks. Thanks, Danny
