Winding Stem Replacement?
NoraE
Jul 26, 2020
73
14
I've got a silveroid Keystone 12s watch case with a sloppy winding stem. I'm thinking that the stem shouldn't be tapered as it is, but am not sure. The sleeve looks to be fine. Could someone please tell me what I'm looking at? If it is in fact worn past it's serviceable life, I have no idea what to look for for a replacement part number or size.
Any help will be appreciated.
Thank you in advance.
richiec
Feb 24, 2007
6,878
627
67
Brick, Ocean, NJ
I believe that taper is normal, not worn at all. When you pull the stem out, it rides over the short protrubance and locks above the larger protrubence, when you push it back it in, it rides over the taper on the small protrubence and locks above it.You more likely have a weak sleeve, examine the sleeve by unscrewing it from the case and look for bent or broken parts.
Reactions: NoraE
NoraE
Jul 26, 2020
73
14
Unscrewing it from the case is how I got the stem out. :) There doesn't appear to be any physical damage to the sleeve. It has a positive click in both directions, but wile in the setting position it has a lot of side slop. How would I determine the size of sleeve needed should I decide to try another one in the future?
Topic related ad experiment
160,812
1,395,252
82,848
Fuzzy
1,099
2,778
