Yes i know, thank you.I believe that Chris Radek rewinds Accutron 214 coils. He's spends quite a bit of time with Accutrons. Good luck.
What happens that coils must be wound?Is there anyone who built an accutron rewinding machine?
Sometimes they burn out and working ones are scarce. I want to try to rewind them.What happens that coils must be wound?
Thank you
Thank you. Had no idea such was possible.Sometimes they burn out and working ones are scarce. I want to try to rewind them.
There are people who rewind them and I'm looking for their help to get started.
Better to ask the experts.Thank you. Had no idea such was possible.
I would wind a new coil myself. How many turns? Anything special abouthe coil, such as being wound from lefto right and each subsequent wind being from left right?
I have wound other kinds of coils.Better to ask the experts.
The 0.015 mm wire will arrive next week from China and then, slowly, I will start.
Ok, sorry.I have wound other kinds of coils.
With no advice available, when unwinding the bad coil, I documented how it was wound and the number of turns.
No need to be sorry. No experts to ask.Ok, sorry.
What kind of machine do you use?
Did you build it yourself?
Thanks, I already read.This thread should have the information you need. https://mb.nawcc.org/threads/accutron-214-coating-coils-after-rewind.149688/
Yes thanks.I suppose you've seen the video already
Did you try sending him a private message? I did notice on his website he's basically Booked to the end of time he's buried in work. But as the image shows below to track him down he still visiting the message board actively so I'm guessing if he wanted to take part in this discussion he would be taking part. But you can still send a private message and see if he responds he might not even respond to that. But even if he does reply it still conceivable that whatever he made is complicated. Of course we won't know until he tells us that otherwise we can just speculate.I was just hoping for some advice
Yes, twice.Did you try sending him a private message?
Yes, i know.But as the image shows below to track him down he still visiting….
