Willard?
dgoerner
Mar 12, 2010
96
13
NJ
Hello All, I was looking through the clocks I purchased about a month ago at the house sale
the person I purchased all the clocks from said that her late husband told her that this Banjo clock was worth more than all of her clocks, I told her I was not a clock collector and did not know.
Anyway I took apart the clock I did not take pictures and now I know I should have.
The only markings on the works is "Willard" almost looks like script.
please let me know how I can know if this is original.
any other details I can look for?
bruce linde
ADMIN / MODERATOR
9,280
1,525
oakland, ca.
clockhappy.com
impossible to tell from that one photo... we would need to see closeups of the dial, interior lower box, weight, pulley, movement, how the movement is mounted, how the side rails are attached, etc.
it's a nice looking banjo clock but doesn't particularly scream 'willard' to me... looks later (just an opinion)
JTD
Sep 27, 2005
9,185
863
Maybe I'm missing something but I couldn't see this on any of the pictures you posted. Can you explain where it is?
JTD
dgoerner
Mar 12, 2010
96
13
NJ
I think you guys are right, it looks to new to be a Willard, the screws the plates the gears.
now to find out
rmarkowitz1_cee4a1
Nov 26, 2009
6,021
1,322
now to find out
As suggested by other respondents, it's most definitely a 20th century banjo.
However, it appears to be of good quality with what appear to be hand painted glasses. I've seen clocks like that sell at auction for very good $$.
A number of makers come to mind from Waltham to Chelsea to Derry to Boston and so on. Some research may help you to pin it down.
Take a close look at the back of the eagle finial. If a Waltham, it will be signed "WCC".
Also, look closely at the glasses for a signature. A guy named Steele did nice glasses like yours and signed them. Somewhere on the MB I posted a tabernacle mirror he did. The posting includes info about him.
I would NOT be disappointed. It's a nice collectible clock, regardless of the completely spurious signature scratched onto the works.
RM
dgoerner
Mar 12, 2010
96
13
NJ
I will check thanks, I se the plates have been damascened(I think that's the word)
Herschede, also did that.
Joeydeluxed
Mar 3, 2007
199
26
I believe your clock is either a Waltham or a Durfee (Waltham made most of the Durfee's).
Very nice clock with a higher than usual quality set of reverse painted glasses.
It is absolutely 100% NOT anything made by any of the Willard family!
clocks4u
Sep 2, 2000
683
27
Oregon
Though Durfee used Waltham movements, didn't they die stamp and number all their movements.
Joeydeluxed
Mar 3, 2007
199
26
Durfee like so many companies who place their name on something they didn't make quite often had the manufacturer leave their name off so as not to be able to identify the maker. Same as (for example) what Sear's did lawn mowers, washing machines, refrigerator, etc. Also, the same with many clocks marked Tiffany. Tiffany quite often did not let the original manufacturer sign the piece and let buyers think they were getting something made by Tiffany. The Durfee's sold at a premium compared to a common Waltham banjo clock. The pendulum bob and grooved rings on the gear on the front of the movement are a giveaway to the maker. (see the additional photo that the original poster added that better shows a movement serial number)
I've had dozens of Walthams and probably about 10 Durfee banjos and am 99% certain that's what this clock is. Durfee banjos did not use stock Waltham glasses but instead used a far higher quality reverse glass painter which is exactly what this clock has.
With all due respect, this not speculation and I stand by my assessment.
Reactions: dgoerner and Dave T
rfyans
Nov 4, 2008
46
Narragansett, RI
I have recently been doing a brief study on early Durfee banjo clocks and came across your thread. Your clock was produced by Walter H. Durfee in Providence, RI. In addition to the characteristics noted by Joeydeluxed, above, another characteristic is the large, gold inner chapter ring on the dial. The lack of a signature on the dial is unusual, but could indicate that Durfee intended to market the clock through a retailer such a Tilden-Thurber. Most of Durfee's movement were supplied by the Waltham Clock Company, as was yours. The serial numbers found on these early style cases ran from about 5500 to 5800. Your low number of 5533 indicates a manufacturing date of about 1906. The early case design is characterized by the squat bracket with seven 7 1/2 inch diameter balls visible The case design was changed to the standard version with a longer bracket and six 6 3/4 inch diameter balls visible from the front.
The glass on your clock is of the highest quality and was most likely supplied by the William Sprague Company or an independent artist. From the date of your clock, it probably wasn't painted by Daniel Steele since he would have been about nineteen at this time. However, most Durfee banjo clocks with the standard version case were painted and signed by Steele.
Your clock has some issues. The movement is missing the club foot gear attached to the winding arbor and the Geneva stop gear. This was a major improvement over the early Willard movements. It is also missing the metal panel that runs down the throat frame to protect the glass from the weight. It is also missing the tie-down that holds the pendulum stick in place whenever the clock is moved, protecting the lower box glass.
Hope this is helpful. If you would like more information, I can be reached by email at richardfyans@gmail.com
Andy Dervan
Gibbs Literary Award
NAWCC Star Fellow
Oct 23, 2002
2,912
131
It appears to be an early original Waltham Clock Co. Willard banjo clock ca 1906. Someone removed the Geneva Stop from the front plate - it often happened as owners or repairers did not know how to properly set it up
I wish you had included photographs of the entire clock for us to see and confirm the case.
This dial is incorrect as it should be flat painted zinc dial with italized arabic numerals and signed Waltham Clock Co. I have several correct Waltham Willard banjo clocks from this early period.
After Waltham Watch Co. purchased Waltham Clock Co. in 1914, it made changes to the clocks. It introduced convex steel dial. This dial was introduced ca 1916 for use on higher end clocks - gold circle inside chapter ring - surprised to see the dial unsigned that is very unusual.
Andy Dervan
Andy Dervan
NAWCC Star Fellow
Oct 23, 2002
2,912
131
Simon Willard did make some deadbeat escapement movements very early that would have required maintaining power, however he quickly switched to recoil escapement as simpler, less temperament to wall placement.
Waltham was the only company making reproduction timepieces in 20th century that had deadbeat escapement requiring maintaining power and geneva stop.
Going forward all makers used recoil escapements. After a very short time - the movements from almost all makers were virtually indistinguishable.
Andy Dervan
bruce linde
ADMIN / MODERATOR
9,280
1,525
oakland, ca.
clockhappy.com
why would deadbeats require maintaining power, but not recoils?
did any of those early deadbeat willards (the escapements, not the family) actually have maintaining power?
Jim DuBois
Jun 14, 2008
3,500
1,040
Magnolia, TX
Simon Willard did make some deadbeat escapement movements very early that would have required maintaining power, however, he quickly switched to recoil escapement as simpler, less temperament to wall placement.
Andy Dervan
Hey Andy,
Some fair numbers of Willard's early work had deadbeat escapements and no maintaining power. His early timepieces were deadbeat. His so-called Grafton wall clocks were deadbeat. His lighthouse clocks were deadbeat. Most of these clocks did not have a suspension spring at all, light bobs hung directly off the crutch connected directly to the verge. They can work very well but I prefer recoil and a suspension spring!
Here are a couple of examples, deadbeat, no maintaining power, no suspension spring.
Andy Dervan
NAWCC Star Fellow
Oct 23, 2002
2,912
131
Why maintaining power:
When winding a clock it stops momentarily and pallets and escape wheel teeth hit it other with recoil escapements that is ok. However with deadbeat escapements it could cause damage so maintaining power provides very short term power to keep clock running and protecting pallet and escape wheel from damage.
Andy Dervan
rmarkowitz1_cee4a1
Nov 26, 2009
6,021
1,322
Hey Andy,
View attachment 588575 View attachment 588576 View attachment 588577
That first movement is interesting. What type of clock was that in?
Reminds me of a type of movement found in Abiel Chandler mirror clocks:
Also see Parsons, page 200, figure 367.
RM
Reactions: Jim DuBois
Jim DuBois
Jun 14, 2008
3,500
1,040
Magnolia, TX
RM
It was found in a coffin clock case which housed the backboard of a Grafton wall clock, So, the correct answer would be it is a Grafton wall clock movement, most likely made by Simon Willard early in his working career, that is when he was still making things himself. Fall off strike on the hour, a strike/silent mechanism/hand, and a hand on the escape wheel arbor to show it was running. No name on the dial but 5 repair dates scratched on the very small "plates" showing repaired by E. Taber all 5 times. That guy missed his calling for spreading graffiti all over. It is indeed sad I never found how to focus a camera 2 times in a row!
rfyans
Nov 4, 2008
46
Narragansett, RI
Hi Andy,
What is the lowest serial number your have found, on an early Willard style banjo clock, with the dial marked "Waltham Clock Co." and the movement signed with the "Waltham Clock Co." stamp. The lowest serial number I found, with these markings, was 5634.
Rich
rmarkowitz1_cee4a1
Nov 26, 2009
6,021
1,322
View attachment 588640 View attachment 588641 View attachment 588643 View attachment 588644
Thanks.
Rather different movement than he put in some of his other "Grafton" wall and shelf clocks, at least as shown in Robinson & Burt.
Very neat stuff!!
RM
Jim DuBois
Jun 14, 2008
3,500
1,040
Magnolia, TX
Per Gary Sullivan, and he has owned and well researched a few, none of these Grafton wall clocks were built alike. I think there are no suggested makers other than Benjamin Willard, Simon Willard, and Aaron Willard Sr. of these timepieces. And Simon is creditied for most of them. Given the Simon propensity to use dead beat escapements without maintaining power, and pendulum bobs that had no suspension springs but hang on the verge arbor, this one, ever so unlike others, still suggest S.Willard to me. But, I could be wrong. By the way, it is 8-day. These bad photos are from the Willard museum from a very recent visit.
"A related movement is found in a Simon Willard wall clock, Zea and Cheney, Clock Making in New England, 1725-1825, page 30;
Provenance: By descent in the Dudley family of Roxbury." "attributed to Simon Willard, Roxbury"
20190628_125401 (2).jpg 20190628_125457 (2).jpg 20190628_125630 (2).jpg 20190628_130037.jpg 20190628_130055.jpg
Andy Dervan
NAWCC Star Fellow
Oct 23, 2002
2,912
131
rfyans
I don't discuss all my research details, but I have recorded lower numbers and own 2 clocks with lower than 5634.
Andy Dervan
168,903
1,473,857
48,649
steveal
2,955
