Will almost sell my soul (almost) for a Kienzle disc pendulum spring barrel......
Discussion in '400-Day & Atmos' started by Ron751, Sep 13, 2017.
  1. Ron751
    Ron751 Registered User
    NAWCC Member Donor
    Sep 2, 2011
    214
    Retired locksmith
    N. Massapequa, LI, NY
    The tough part is that it's a Kienzle barrel for a 400 day disc pendulum clock. I am working with Chris from Horolovar on this restoration. He told me that this barrel is unique to Kienzle movements of this type ONLY.
    The reason being is that the barrel rests against the back plate which according to Chris is unusual as compared to other 400 day clocks.
    The existing barrel has 4 flattened teeth - I will get it repaired only as a last resort if it affordable.
    Except for the basic small parts needed (Horolovar supplied) to finish a 400 day clock, it's ready for that setup process.
    Needless to say my frustration level is quite high…
    Everyone on the forum has been so helpful & patient during my membership. I have been taught a ton of things about clocks & the time that you all have saved me is immeasurable. I am hoping that someone will remember that they have a barrel buried away in a dusty box….
    I will give the dimensions of the barrel, even though I think a Keen Kienzlexpert will understand the situation right away without them.
    72 teeth
    Diam. w/teeth > 42.2 mm
    Diam. w/o teeth > 39.3 mm
    Inside depth > 21.6 mm
    Height > 23.3 mm
    BTW > Serial #16277
    The way Chris explains it is that the incorrect barrel will be jammed up against one of the plates.
  2. etmb61
    etmb61 Registered User
    Oct 25, 2010
    1,561
    10
    Mascoutah, IL
    Have you posted a picture of this movement? From the number I would think you have one made by Huber for Kienzle.
    Eric
  3. etmb61
    Oct 25, 2010
    1,561
    10
    Mascoutah, IL
  4. MartinM
    MartinM Registered User
    Jun 24, 2011
    2,333
    14
    El Dorado, CA
    I believe it's the one that has the winding arbor on the side without the cap and is a pain to get the spring in and out of without a clockwise winding arbor for your spring winder.
  5. shutterbug
    shutterbug Super Moderator
    34,670
    46
    If you jump over to the clock repair forum, there's lots of information on how to replace teeth on a barrel. You might feel up to the challenge yourself. Otherwise, there are members here who do great work. One is David LaBounty who is a master clock maker and his charges are quite fair.
  6. Ron751
    NAWCC Member Donor
    Sep 2, 2011
    214
    Retired locksmith
    Sorry for not including pics - These should give all of you a full overview of the situation.
    Thanks Shutt for mentioning Dave LaBounty - I am familiar with his reputation.
    Note> I was told that the susp. unit holder is not correct (U shaped)
    Thanks all for replying !
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  7. etmb61
    Oct 25, 2010
    1,561
    10
    Mascoutah, IL
    #7 etmb61, Sep 13, 2017
    Your clock was made by Wurth, not Kienzle! Wurth only made about 28000 clocks total, so your best bet is probably fixing what you have.
    Also, I believe your suspension bracket is a Kern part. The proper part should be the gimbal type, number 14 in the repair guide, see below.
    Eric
  8. Ron751
    NAWCC Member Donor
    Sep 2, 2011
    214
    Retired locksmith
    Thanks Eric - so does that make my hunt for a barrel harder now that we know it's not one of the big companies ?
    Ron
  9. etmb61
    Oct 25, 2010
    1,561
    10
    Mascoutah, IL
    I would say so. I don't have a Wurth apart right now, but I would compare a Schatz 49 barrel and see if it's close in size and tooth count.
    If it were a Kienzle you could probably have used a Kern barrel, since Kern bought out their 400 day production line.
    Eric
  10. Ron751
    NAWCC Member Donor
    Sep 2, 2011
    214
    Retired locksmith
    OK - getting the barrel repaired seems the easiest thing to do now. I know who to go to.
    As far as the suspension bracket goes - are the gimbal types obtainable ? I don't want to go thru the hassle of the barrel situation again. I could live with what I have if necessary - but hey, correctness is always cool !
    Thanks Eric for clearing up some big issues.
    Ron
  11. etmb61
    Oct 25, 2010
    1,561
    10
    Mascoutah, IL
    The suspension bracket is probably easier to make than to find. I found the one shown above online about five years ago, but I had to pay more for it than I have for some entire clocks. Ouch!
    Eric
  12. Harry Hopkins
    Harry Hopkins Registered User
    Nov 16, 2011
    265
    Retired Instrument Technician
    Mason, IL
    I noticed that the area of the barrel hook is bulged out which means that the hook itself is probably starting to get loose in the barrel. If you decide to replace the flattened teeth you should also address the barrel hook.
  13. Ron751
    NAWCC Member Donor
    Sep 2, 2011
    214
    Retired locksmith
    Thanks Harry - it was noted & will be taken care of.
    BTW - your shop is beautiful & so well organized. I wish that I could incorporate some of those features.
    unfortunately my area was a regular shop in my basement before I decided to get into clocks.
    There's too much non-clock related stuff around......some day......:-}
  14. Ron751
    NAWCC Member Donor
    Sep 2, 2011
    214
    Retired locksmith
    Bless you, Eric. You bring out the utmost in nuttiness in us clock people. When the part has to be correct - to blazes with the cost ! I think a lot of us would have done what you did. Besides, anything on gimbals ALWAYS looks cool :-}}
  15. etmb61
    Oct 25, 2010
    1,561
    10
    Mascoutah, IL
    Still, the most expensive parts I've purchased have all been pendulums.
    Eric
Similar Threads - almost sell soul Forum Date
Huber "patent angemeldet" almost complete 400-Day & Atmos Jan 30, 2016
Almost twins 400-Day & Atmos Jul 27, 2013
