Why one pivot on the entire movement
Discussion in 'Clock Repair' started by Rockin Ronnie, May 13, 2018.
  1. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,444
    86
    retired educator
    Greenfield, Nova Scotia
    Every pivot on this Gilbert time and strike (1906) movement is in very good condition except for this, the second wheel on the strike side, front pivot.
    Why?
    I have never replaced a pivot but I am thinking that this will be one that should be replaced.
    Ron
  2. shimmystep
    shimmystep Registered User
    Mar 5, 2012
    4,085
    75
    Cambridge, UK
    probably down to a combination of reasons, i.e. it being the second wheel and so being under more axial load, and probably a contaminated pivot hole, detritus embedded. I'd def re-bush the hole.
  3. wow
    wow Registered User
    Jun 24, 2008
    3,580
    162
    Retired Music Minister
    Pineville, La. (central La.)
    Yes, like Shimmy said, just turn down the pivot and polish it. It looks like from the photo that there is enough steel left to use it after it is turned down. Then install a new bushing to fit the new pivot size. Easier than re-pivoting
  4. Uhralt
    Uhralt Registered User
    3,855
    386
    Yes, definitely. there must be something very abrasive in that pivot hole. A new bushing will change that.
  5. Rockin Ronnie
    Nov 18, 2012
    1,444
    86
    retired educator
    Never thought of turning down the pivot and yes, I think there's enough left. thanks.
    Ron
  6. Rockin Ronnie
    Nov 18, 2012
    1,444
    86
    retired educator
    Did the repair and installed the new bushing. Looks like I saved a lot of work, thanks Shimmy.
    Ron
  7. shimmystep
    Mar 5, 2012
    4,085
    75
    Cambridge, UK
    Glad you have it sorted, nasty bit of wear that.
  8. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    NAWCC Life Member
    Jul 4, 2009
    2,247
    68
    Diistributor of movements and movement parts.
    Muscatine, Iowa 52761
    It is possible that pivot was never polished properly in the first place.
  9. claussclocks
    claussclocks Registered User
    Mar 14, 2013
    720
    178
    Texas
    #9 claussclocks, May 15, 2018
    I just did one like that this morning on a Sessions. If you laid them side by side you would think they were the same thing. I just turned it down with an Arkansas stone, polished, and re-bushed the hole. Works just fine. Those American movements can spare quite a bit of pivot material and still be good.
    You might consider checking your mainspring. If you don't mind the investment going from a .018 to a .0165 spring might help. Those old springs really over powered some of those systems. Don't get an Indian made spring if you can help it. Not very consistent in manufacture.
    I got a clock in one time from a lady who had moved from Tucson. Almost every hole and every pivot were near a third to a half gone. All that sand had just ground out holes and it was like putting the pivots on a grinding wheel
  10. Rockin Ronnie
    Nov 18, 2012
    1,444
    86
    retired educator
    I was thinking the same thing. Like you I ground it down on my lathe and polished it. The movement doesn't have a case. I picked it up at a flea market for $10 to basically practice on. It had been worked on before, new bushings, solder etc. and I suspect the mainwheel had a replacement (perhaps overpowered) mainspring owing to the unusual wear on the second wheel. As I mentioned every other pivot was in great shape.
