I asked folks about a jewel replacement.
That one will just have to be put off for a while.
Other things that have come up, like really having to go put a gutter and downspout on the back of the house so the wall there will not rot out...
I have an 0S Waltham that has a staff that is juuuuust a bit gone on the end. Trying to place the hairspring in the guides and see if the watch would try to run,,, the hairspring had a rust spot and broke,,, had to put that aside... Have a Waltham 12S that has an issue running in on the edge position, I think the balance staff will need to be replaced, The hairspring looks Kosher.
I am practicing with other things to make ready to replace a staff.
I have perhaps 3 or 4 to do...
I took apart a staff and metal table and metal roller, from a balance and I have just gotten a small stake plate. I needed this to have something with enough room over the top to do the installation phases.
My staking kit is for wrist watches and is very small clearance over the top of the plate and has limited holes, (at least not close to the size of my stumps) Grrrrr!!! I bought some stumps online and as a little chore I added a hole on my vises to accept the large stumps. Tempted to drill the hole I need in the plate on the staking set up...
I built a riser for my bench, and found I need to cut that down...
I had to add a big pillow in my chair to go up, but that will not be comfortable. This is getting like mixing concrete! more water then more mix till luck visits you
Any way Thanks to all the folks here who help me out!
Dave.
Dave.
