Why don't we ever see.....
Discussion in 'American Pocket Watches' started by butlercreek, May 18, 2017.
  1. butlercreek
    butlercreek Registered User
    Mar 8, 2007
    73
    Any 16 or 18 size solid white gold cases?
  2. John Cote
    John Cote Registered User
    Aug 26, 2000
    3,411
    11
    Photographer
    Midwest USA
    I think I may have see a 16s or two but not an 18. Gold is prestige. I think people who bought gold cases didn't want their watches confused for cheap metal watches.
  3. rrstd
    rrstd Registered User
    Feb 18, 2001
    1,558
    I seem to remember reading that white gold didn't really become popular for use in jewelry and watches until sometime in the 1920's. By that time, 18 size production had pretty much ended and the 16 size watches were being replaced by the smaller 10-12 sized models. At the same time, wrist watches were becoming much more popular.
  4. novicetimekeeper
    Jul 26, 2015
    4,818
    Dorset
    I always think of white gold as entering with art deco. They rhodium plate it to get it extra white, otherwise it is always a bit yellow, and pocket watches are high wear so I would have thought not ideal.
  5. Greg Frauenhoff
    Greg Frauenhoff Registered User
    Aug 25, 2000
    3,757
    7
    Agreed.
  6. butlercreek
    Mar 8, 2007
    73
    Agree to disagree :) my wife has a lot of Victorian and Edwardian filigree jewelry in 14 and 18k white gold (and platinum), so I know it was popular in the mid to late 1800's...
  7. GeneJockey
    GeneJockey Registered User
    Mar 2, 2012
    841
    Scientist
    I would add to this, that even though 16s watches continued to be produced for most of the 4 decades after 1920, they were increasingly 'working' watches, rather than dress watches. In the 1942 Elgin catalog, the 16s watches were billed as "Transportation" models - for railroaders and such. None were listed as available in solid gold cases. OTOH, the 12s and 10s dress watches were available in solid gold and platinum, in addition to gold filled.
    Funny thing about this thread, though, is that I just snagged a white gold filled, 16s BW Raymond Model case for a ~1928 Elgin 478 movement I'd bought.
  8. Greg Frauenhoff
    Aug 25, 2000
    3,757
    7
    I can't speak to jewelry, but being very familiar with watches (and numerous period ads in the trade journals of the time) I can say that, as Rhett noted, white gold watch cases did not come into vogue until c. 1920. And by then 18s watches were disappearing in general and, as GeneJockey noted, 16s watches were (in general...there are always exceptions) no longer dress or for fancy occasions. Most white solid gold pocket watches are 12s (or 10s or 12 x 14s, etc.) from the 1920s and later. White gold-filled began appearing around the same time (1920s) and was certainly used for 16s cases but any such 16s in solid white gold are certainly scarce.
  9. novicetimekeeper
    Jul 26, 2015
    4,818
    Dorset
    I'm surprised, is that an American thing? Here definitely platinum settings were used but mostly silver to set the diamonds off.
  10. Nigel Harrison
    Nigel Harrison Registered User
    Oct 30, 2005
    731
    I have read the history on white gold some time ago out of interest and from memory it was not actually formally created until very late 1800's(around 1890 from memory) and one firm/name was seen to be the creator, it did not become mainstream used until early 1900's where more manufacturers started using it also. The story I read on white gold did basically say that if you see a genuine white gold stamped piece before 1910ish then it is an uncommon piece and really is a collectors item in its own right due to scarcity of use from 1890 to 1910. Even better is if you find the piece marked with the makers name, usually that company name that created the metal...I cannot remember that name from memory but it started with and S I believe. This is why you only see white gold become apparent in the 1920's in watches and Jewellery as it was not mainstream used until 1920's...and to reconfirm details with others stories here that have already been stated, in 1920's art deco period 12 and 10 size mens watches plus wristwatches were becoming the fashionable mainstream pieces. 18s pieces were not common and being phased out and 16s pieces were more for the worker (larger hardwearing) so soft solid gold pieces were not preferable in these 'working' watches, usually these pieces were in basemetal, silver or gold filled. As most people know here some 16s hamilton and illinois solid gold white, green, yellow cases were made in railroad style but were scarce and really a show pieces for well off 'people'.
    I do look at jewellery quite a bit and most white metal jewellery pieces I see prior to 1900 are usually platinum or sterling silver, very rare to see actual solid 'white gold' stamped as mentioned. If you have jewellery marked 14k and 18k gold that is prior to 1900 and is white in appearance check to see if it is actually 14k or 18k yellow gold has been rhodium plated or white gold plated to improve its look later in the 1920's or later as this was done quite a lot. If it is not stamped 'white gold' then question if it is. Very hard to tell unless you were to wear down the piece somewhere though. The rhodium plating of jewellery in later periods has also been mentioned and discussed on the TV show Antiques Roadshow in the past as well. The use of white gold really only started to be used in the later Belle Époque period (1890-1915) but still scarce then as platinum and silver was the preference. Once again white gold in jewellery or watches was only more mainstream in 1920's and later.
    More details on detail Victorian jewellery styles and metals used can be seen here and even breaks up the period of Victorian jewellery into three inner periods://www.gemsociety.org/jewelry-lapidary/antique-and-jewelry-history/
    You can see they do mention white gold is not used specifically in the Victorian period.
  11. dAz57
    dAz57 Registered User
    Dec 7, 2011
    1,880
    7
    watchmaker
    sydney Australia
    Well I was going to say a lot would have disappeared in the 70s when gold shot up from $35 an ounce, I've seen plenty in gold, silver and occasionally in platinum, white gold can look too much like cheaper metal.
  12. topspin
    topspin Registered User
    Dec 14, 2014
    1,158
    Yes, I never quite got the point of "white gold". If someone is going to produce something in whitish/silvery-colour metal then why waste a load of perfectly good gold bulking it out?
  13. Jerry Treiman
    Jerry Treiman Registered User
    Donor NAWCC Member
    Aug 25, 2000
    5,061
    19
    Geologist - California Geological Survey
    Los Angeles, CA
    The only white precious metal that I see competing with white gold might be platinum. Other white metals either tarnish, or don't have the same luster and workability. I had the impression that when white gold was gaining popularity in the '20s it was a poor man's platinum. Today the tables seem to have turned as platinum is now cheaper than gold.
  14. Jeff Hess
    Jeff Hess Super Moderator
    Donor Sponsor NAWCC Member
    Sep 3, 2000
    6,335
    watches
    Florida
    great time to share one of my mega-rare white gold railroads.. 18k white gold no less. Sidney Y. Balls personal watch.
  15. Bryan Eyring
    Bryan Eyring Registered User
    Donor NAWCC Member
    Dec 11, 2007
    1,472
    7
    Medical Product Design Engineer
    What size / grade
  16. Tom McIntyre
    Tom McIntyre Technical Admin
    Staff Member Donor Sponsor NAWCC Member
    Aug 24, 2000
    77,826
    396
    146
    retired SW dev
    Boston
  17. PWfanatik
    PWfanatik Registered User
    Jul 7, 2015
    936
    Building trades Project Manager
    My vote is for the fact that Gold does not tarnish...
  18. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    620
    Science teacher, writer
    Lancaster, Ohio, USA
    I don't work on pocket watches, but I do have a reproduction of a 1927 Sears catalog. Every watch listed, pocket watch or wrist watch, ladies' or mens', is either nickel, nickel-plated, white gold or green gold, either solid or gold-filled. The only yellow gold case I found was on a Hamilton railroad watch.
    M Kinsler
  19. Jeff Hess
    Sep 3, 2000
    6,335
    watches
    Florida
    16 size 23j with governemnt timing certificate.
Similar Threads - don't ever Forum Date
My first ever size 16 watch. American Pocket Watches Jun 25, 2017
Possibly the most ignorant question a newb can ask - but if I don't I'll never know : American Pocket Watches Jun 27, 2016
Illinois Pocket Watch - I Don't Know Where To Start American Pocket Watches Jul 7, 2014
Elgin grade 527 16s 19j adj3p, 11K made but they don't appear to be that common American Pocket Watches Dec 11, 2012
RR Watch Gets Right Of Way In Court, Or Don't Use A Silver Watch American Pocket Watches Apr 7, 2012
