Why do clocks apparently need time to settle down
ChrisCam
Dec 9, 2017
1,440
31
England
Hi Guys,
Almost embarressed to ask this but several clocks after travelling (for instance a clock I have bought via the post to service at some point in the future) have worked for a few hours sometimes a day or more then stop. The thing is after a few days sometimes a week or so they often have kept going without any good reason. Is there a sane reason for this?
Regards
Chris
ChrisCam
Dec 9, 2017
1,440
31
England
You answered your own question when you said that you bought them to service at some time.
I should have said that having bought an old clock I would expect to have to service it. But yes you are right it must be in need of servicing and once stopped it firms up a little, then may loosen up when going again for a while. That's the theory then...sounds good to me.
Chris
4,995
611
If a clock has not been running for some time the old oil/dirt mixture in the pivot holes has become quite stiff and may stop the clock from running. When the clock has been running continuously (or on and off) for some, time this mixture becomes less viscous and is also transported partially out of the pivot holes. That will reduce the friction somewhat so that the clock may continue running. Overall this indicates that the clock needs a service.
Some weight driven antique clocks, especially those with wood frames, like Black Forest clocks, will change the shape of the frame when hanging on the wall under the stress of the weights. It may take some time to get back to the favorite shape if they have been off the wall for a while.
Reactions: Jmeechie
leeinv66
Mar 31, 2005
10,133
248
Launceston Tasmania
And remember the clock movements we work on are made of dissimilar metals. Brass and steel expand and contract at different rates, so a tight bushing in a cold climate can become a too tight bushing in a warmer climate. Just saying.
Les harland
Apr 10, 2008
1,554
146
Hertfordshire England
I have seen that "problem" with a watch
Some time ago I bought an Enicar military watch about seventy years old
It lost about four hours in the first twenty four hours it ran
The next day around two hours reducing every day until after a week it became a superb timekeeper
I think clocks and watches are like humans, they become more cussed with age
ChrisCam
Dec 9, 2017
1,440
31
England
Thanks for replies Guys the only additional thing I can think of is when a clock is transported it is often put in a box laying on its back. thus all end plays and teeth position on gears can shift.This also can happen during be transported even if placed upright. There may well be sweet spots for meshing gears. This plus as Uhralt says case movement and viscosity of grime are all factors apart from the obvious crutch / pendulum adjustment and climatic differences. Clocks may not like being transported.
Regard to all
Chris
Reactions: Jmeechie
Topic related ad experiment
160,936
1,396,127
82,919
Manfercas
1,099
2,788
