Who Made This Movement
Discussion in 'Clock Repair' started by sylvester12, Nov 4, 2019.
  1. sylvester12
    sylvester12 Registered User
    Oct 17, 2015
    619
    94
    Hi does anyone recognize who made this movement. It has two broken mainsprings just wondering if its worth fixing or not.
  2. Willie X
    Willie X Registered User
    12,774
    985
    Posably a Junghans. It should be an easy job to replace the springs, assuming nothing is broken. I'm pretty sure his movement has bayonet style barrels, so be sure to figure out exactly how they are made before taking the gear plates off. They should come apart easly, without using much force. Willie X
    sylvester12 likes this.
  3. sylvester12
    Oct 17, 2015
    619
    94
    Thanks Willie X much appreciated.
  4. shutterbug
    43,484
    1,241
    The springs more than likely broke at the ends, and can be re-holed and used. New springs are not reliable these days unless you can insure they are not made in India.
    It's pretty odd though, that both springs would be broken. Are you sure it's not the clicks?
  5. JimmyOz
    JimmyOz Registered User
    Feb 21, 2008
    507
    91
    Looking at the front of the movement it does look as, at least, the left click spring is to far away from the click.
  6. shutterbug
    43,484
    1,241
    Agreed. It looks bent upward.
  7. JTD
    JTD Registered User
    Sep 27, 2005
    7,668
    512
    I agree - and not only does it seem to be bent upwards, it also seems to be much thinner gauge wire than the other one.
    JTD
  8. sylvester12
    Oct 17, 2015
    619
    94
    Hi thanks for all the comments on the movement. The springs on both trains are deformed at the winding arbors, it needs click wheels, clicks and springs. Someone has really played with this clock and it's not worth fixing. It's just a 40s mantle clock.
  9. Willie X
    12,774
    985
    Replace or repair the click wheels and click springs Reform the inner coils of the main springs and give it a shot.
    This is basic clock repair, like clock repair 101. So, if you are wanting to learn clock repair, the teacher is sitting there in front of you ...
    WIllie X
  10. sylvester12
    Oct 17, 2015
    619
    94
    Hi will the springs keep their shape when I reform them or will the arbor slip again. The springs are probably 1/4 inch away from the arbor on all sides.
  11. sylvester12
    Oct 17, 2015
    619
    94
    I basically bent the springs so they fit the arbor tight and put the movement back together. It runs ok but I told the person who owns it not to run it because it's not safe the click wheels and clicks are bad
  12. Willie X
    12,774
    985
    Yes, a click failure often results in the unwinding of the center coil.
    It's not a good idea to let anything leave your shop with faulty winding parts. This can spell bad news for your customer, the clock, and you. It's a lose/lose/lose situation!
    WIllie X
