Who is "John Lawrence- Lancaster" Tall case dial
Discussion in 'General Clock Discussions' started by Jeff Beehler, Sep 14, 2002.
  1. Jeff Beehler
    Jeff Beehler Registered User
    Dec 18, 2001
    I happend across and came into aquiring a tall case clock. I call it that but it stands only 7 ft. tall. The case is a flat top, mahogany and oak, brass pillars at the pole ends at each side of the door and a 13in. square "heavy' brass dial which has incribed in a circle (where a calendar bit is usually located)below the hand shaft hole "John Lawrence"(engraved in script with all the curly cues) Lancaster. This dial has cast brass corner spandrels and a calendar bit where the second bit usually is. Can anyone shed any light on what I found? I can e-mail pictures on request. The only thing I can find is listed in Disten & Bishop Lawrence, John, Philadelphia c.1790
    Thanks in advance
    Jeff Beehler
  2. Jeff Beehler
    Dec 18, 2001
    Thanks in advance
    Jeff Beehler
  3. gre406
    gre406 Registered User
    Oct 6, 2001
    611
    Jeff..Email me photos and I will post..
    Geo
  4. David Thomas
    David Thomas Registered User
    Aug 28, 2001
    227
    UK
    John Lawrence worked in Lancaster (England) from about 1762 to about 1800. There is a picture of a clock by him in "Clockmakers of Northern England" by Brian Loomes on page 156. It matches your description.
    Regards
    Dave
    [This message has been edited by David Thomas (edited 09-14-2002).]
  5. gre406
    Oct 6, 2001
    611
  6. David Thomas
    Aug 28, 2001
    227
    UK
    The general style and the engraving of leaves is identical to the dial shown in the book. I am not an expert but I would date it about 1780.
    Dave
