Good evening, all!
I may need to install a bunch of quartz fit-up movements in former Hahl pneumatic clocks in a public building (The Hahl system is almost certainly irreparable). Would like to use radio-controlled movements so that they won't have to reset time in the spring and fall, and so that they'll stay accurate. (Some of these clocks require tall ladders to reach, so nobody wants to have to get up there any more often than absolutely necessary.)
Any ideas on what's the best radio-controlled quartz fit-up? Need something reliable, ideally with long battery life. Fortunately, none of these clocks uses a second hand, so no worries about that. And, largest hands are no more than about 12 inches long, so although high torque might be desirable, we can probably balance the hands to help the torque situation as well.
Thanks in advance for your help!
Best regards!
Tim Orr
Best regards!
Tim Orr
