bbodnyk
So I have an E. Ingraham movement that needs the escape wheel pivot holes bushed. The clock as I received it had a secondary cock attached to the original as in the first picture. And yes, the screw is a sheet metal screw. After cleaning it it runs without the cock as in the second picture. One can only imagine the person who did this didn't know about bushing a clock. Incidentally this solution is workable only because the pivots project fairly far out past the plates.
So which hole do I bush? Do I keep the "novel" repair because it maybe adds some character to the clock or do I remove it and bush the original hole? I'm inclined to keep it. It is a somewhat ingenious if not absurd solution. It also had to take the person sometime to make it. The sheet metal screw only adds to the absurdity I think!
Bruce
Bruce
