I am in the process of learning to put bushings in by hand. I have disassembled an old Urgos UW47128 movement in order to practice this, as was recommended to me on this forum. I found a hole to bush and went through the process today. I'm pretty happy with it.
Now for my next step. In the last few weeks I have disassembled and cleaned an Urgos UW03051B movement removed from my running grandfather clock. There are at least three holes that need bushings. One of these is the minute wheel's hole on the front plate.
Below is info on the hole:
Original Hole: My estimate is 3.25mm using the non-cutting end of a #30 drill bit I was able to use as a gage pin
Elongated hole: 3.55mm (visual estimate)
Projected bushing hole size minimum: 3.55 - 3.25 = .3, 3.55 + .3 = 3.85mm
Pivot: 3.17mm
I believe my KWM bushing options are:
L80 (or L50, L51 which I don't have but would mean less work to increase the ID)
- Only 1.7mm in height
- Uses V reamer (OD=5.85) so a larger hole would be needed than the option below
L144 (or L145 which I don't have but would mean less work to increase the ID)
- height is 2.7mm, so I'll have to file this down
- Uses IVa reamer (OD=4.66) which I don't have and is $45 at timesavers (not a problem to buy if this is clearly the better option)
So which bushing should I choose since I have both L80 and L144 bushings? Or is there a different option?
Thanks in advance for your advice...
Kevin
p.s. I should tell you that even though I am a newbie, I have inherited all my father-in-law's tools and supplies so I have all kinds of KWM bushings, the reamers, etc. Since he doesn't have a IVa reamer but he had L144 bushings, I assume he just used a broach to size the hole, but I will probably by the tool if that is the right option.
Pivot: 3.17mm
Kevin
