Which Balance Staff for 18s Waltham M1892 # 18136878 Appleton Tracy
Discussion in 'Watch Repair' started by HUDD, Sep 9, 2017.
  1. HUDD
    HUDD Registered User
    Apr 11, 2004
    527
    15
    Retired Chartered Surveyor
    St. Albans, UK
    Hi All
    I have a new 1703A staff for my Waltham Appleton Tracy pocket watch but the diameter that takes the rollers is smaller than the broken staff I have just removed. The rollers just slide off this new staff. Is this the correct replacement or should I be looking for a 1703 staff ? Any help would be appreciated.
    Mike
  2. richiec
    richiec Registered User
    Feb 24, 2007
    6,460
    362
    automotive warranty inspector
    Brick, Ocean, NJ
    From what I understand, the 1892 went through a lot of changes in its run. I have 4 vials of staffs, 1703 and 1703A and can definitely see the difference between the roller shaft between them. If you can measure the diameter of yours and give me the pivot size, maybe I have something that will fit.
  3. HUDD
    Apr 11, 2004
    527
    15
    St. Albans, UK
    Hi Richiec
    Many thanks for your reply. Using my digital calipers the diameter of the roller shaft from the broken staff removed is 0.56mm and the spare 1703A I thought would fit has the equivalent diameter of 0.54mm. That is 0.02mm too small. If you do have a suitable staff I would be very grateful.
    Mike
    - - - Updated - - -
    Sorry RichieC I forgot to check the pivot size. As far as I can ascertain its a #11
    Mike
  4. Dave Coatsworth
    Dave Coatsworth Forums Administrator
    NAWCC Business Sponsor
    Feb 11, 2005
    6,473
    1,315
    Watch Parts Dealer
    Camarillo, CA
    The only difference between the 1703 and the 1703A is the hub length, which is 0.3mm longer on the 1703A. This makes the staff 0.3mm longer overall. (6.0mm vs. 5.7mm) The roller diameter is the same on both and should be 0.60mm.
  5. Ticktinker
    Ticktinker Registered User
    Jul 7, 2015
    1,067
    Construction Inspector
    Houston Texas
    Hudd make sure your roller is not cracked.
    This can happen during removal...
  6. richiec
    Feb 24, 2007
    6,460
    362
    Brick, Ocean, NJ
    I agree with Dave, every staff I measured, had a .60 mm roller shaft.
  7. HUDD
    Apr 11, 2004
    527
    15
    St. Albans, UK
    Hi RichieC, Dave and PWfanatic Many thanks for your replies. Now I know the difference between the 1703 and 1703A staffs. I've checked both rollers and they are both ok with no cracks. I'm not 100% sure about the accuracy of my digital calipers though when it comes to very small dimensions but they do show a difference in diameters between the removed broken one and my NOS spare. I've seen a 1703A on "that" website that looks to be the correct one so I'm going to buy that one. Fingers crossed !
    I'm not too familiar with the 1892 Walthams but fell in love with them reasonably recently. I used to collect 18s Hamilton and Illinois pocket watches for over 10 years so I accumulated plenty of spares for these.
    Mike
  8. Ticktinker
    Jul 7, 2015
    1,067
    Houston Texas
    Use some strong magnification on the roller and get close and see if there is a crack...
    Depends on your vision, so 15X 20, or 25 magnification should be adequate...
    I would mount the staff with a small amount of staking and test install the balance cock to see if the balance will spin, then go back and finish the staking...
