Where do these clips go?
Discussion in 'Clock Repair' started by tracerjack, Sep 11, 2017.
  1. tracerjack
    tracerjack Registered User
    Jun 6, 2016
    182
    When I began to unscrew the bolt on the bracket that held the movement in place, a brass clip fell out. Then the second one too. Since they fell out as soon as I loosened the bolt, the slot in the clip must go around the bolt, but I don't know if it went between the movement and the bracket, or between the cable plate and the bracket. Or maybe I'm all wrong, and they went somewhere else. Here's some photos. The movement is a Kieinger bim-bam from 1977. And now can't remember if the cable plate was next to the movement or below the bracket arms. Took all kinds of photos of the movement, but not how it went into the bracket.
    [​IMG][​IMG][​IMG]
  2. wow
    wow Registered User
    Jun 24, 2008
    2,187
    Retired Music Minister
    Pineville, La. (central La.)
    If you put the shims above the racks, they will raise the movement the thickness of the shims. Perhaps it needs to be up that much so it will fit the case. I see no Need for the shims otherwise.
  3. tracerjack
    Jun 6, 2016
    182
    Ah, so they are shims. I didn't know what they were so didn't know what they did. Now I know. Thanks.
  4. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    NAWCC Member Donor
    Jul 4, 2009
    1,882
    Diistributor of movements and movement parts.
    Muscatine, Iowa 52761
    I think the shims should fit under the pillars and between the plates to keep the pillars from being drawn down too tightly. If they are too tight without them it could jam the clock.
  5. tracerjack
    Jun 6, 2016
    182
    I believe you are absolutely right. I had to put the dial on the movement, so took a closer look at the shims. They are the exact depth from pillar to the bottom of the plates, and in length they fit perfectly between the plates. They would do exactly what you posted - prevent the pillars from being distorted by any over tightening of the bracket bolts. Thanks.
Similar Threads - Where clips Forum Date
Anyone know where Tinker Dwight is? Clock Repair Oct 15, 2017
What we don't post where maybe we could have. About reading post titles and threads. Clock Repair Feb 10, 2017
Two x broken arbors, both at the point where the pins should go.... best options? Clock Repair Jan 8, 2017
Bent arbor - unable to find where Clock Repair Dec 9, 2016
C-clips Clock Repair Aug 16, 2014
