bkerr
I have a customer that has a HM GF clock that called to have it checked out. It is 30 years old and they decided to put a new movement in it, that is the easy part. The movers broke the side glass panel. While I was there to get what I needed for the new movement and testing before I return to install I went ahead and removed the broken glass and got some measurements to have a piece cut. The glass sits in a rabbit in the wood on the vertical sides but has a "U" shaped brown piece of rubber / plastic that runs the length of the glass. I don't have it in front of me but I think it is about 42". The staples that held it in place are in the bottom of the U and are rather short. I have plenty of tools but I do not have a nailer that could get that close to the glass. I am thinking about silicone and taping it off until everything is set up. Another thought was using a glass retainer but I don't think that will look right. I sure would like to to repair as close to factory as I can.
Ant Ideas?
Thanks in advance
Ant Ideas?
Thanks in advance
