What type of chain for an Urgos grandfather clock movement?
Discussion in 'General Clock Discussions' started by Rgoodwin02, Mar 17, 2017.
  1. Rgoodwin02
    Rgoodwin02 New Member
    Mar 16, 2017
    Hello all,
    I picked up a 1980's-ish Ethan Allen Grandfather clock for free, it was about to be discarded (possibly for a reason...).
    The cabinet was damaged and I repaired it. I have the weights and pendulum and I know how to place them (I weighed them).
    However, I am missing all the chains. I would like to replace the chains to see if it works at all.
    I realize it is old and that the Urgos 32316 movement is probably heavily worn.
    At this point, I am just tinkering in my carpentry shop. It is a beautiful cabinet at least.
    I believe I need to know links per inch or foot, and I will need to buy hooks and ends as well.
    Can anyone specify the chain and suggest sources?
    Thanks,
    Rory
  2. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    If you google 'urgos 32 chain' you should get several links including one that has an 800 number hotline for Urgos movement questions. They should be able to take the full movement number information from your clock and help you with the proper chains.
  3. upstateny
    upstateny Registered User
    Oct 2, 2015
    290
    I believe the 32316 is the old 32/19 movement, if so it would use 46.5LPF of 1.7mm chain.
Similar Threads - type chain Urgos Forum Date
What is so special on this type of clock? General Clock Discussions Jul 31, 2017
fusee(s): chain vs. cable accuracy w/ temperature changes? General Clock Discussions Jun 25, 2017
what determines pendulum type... rod length or bob size? General Clock Discussions Apr 20, 2017
What type and number of finials are historically correct for English tall case clocks General Clock Discussions Mar 15, 2017
German/Austrian Vienna type Regulator movement identification General Clock Discussions Sep 11, 2016
