What to do about punched pivot holes?
Elliott Wolin
Nov 18, 2019
509
81
67
Williamsburg, Virginia
The few times I've come across punched pivot holes, usually one or three punches, the hole was no good and I rebushed. But now I see one that is punched but appears to be in otherwise in good condition, i.e. round and correct size.
I'm tempted to drill out the abomination and rebush anyway, but I'm wondering if anyone just leaves them the way they are if they look good?
Altashot
Oct 12, 2017
371
115
46
In my opinion, if it has been punched, it’s not good, there was obviously a problem there for someone to punch it in the first place.
I’d bush it.
M.
JimmyOz
Feb 21, 2008
1,088
279
66
Gold Coast Qld
Punching pivot holes was the norm in the past, today we bush. If the pivot hole in your movement is good I would leave it, if you start to bush every punched plate you come across you will be bushing the whole plate on some movements.
wow
Jun 24, 2008
5,835
743
76
Pineville, La. (central La.)
When a hole is punched, only the outer portion of the hole is closed and the lower is still oblong. It just makes sense that a punched hole will not last long because only the outer portion of the pivot touches the outer part of the hole. If rebushed, the pivot touches the entire bushing ID. In my opinion, that is more important than how bad the punches look. I bush them.
15,562
2,103
Bush em ... you will be surprised at how much of the ugly the bushing covers up.
Reactions: Kevin W.
JimmyOz
Feb 21, 2008
1,088
279
66
Gold Coast Qld
Maybe I did not explain that as well as I could have;
What the OP is saying, he wants to take 'out' the punch marks, of course you would bush the plate , however, to take the punch marks out you would need a large bush on every pivot hole. Think of a antique GF, you do a normal bush that fits the pivot, however, to get rid of the punch marks it would need a very large bush, if you don't make your own then a bush in a bush.
48,128
2,381
I agree with bushing. That will clean up most of the punching marks. Whatever remains is part of the clocks history and would not concern me much.
Reactions: Altashot
R. Croswell
11,214
1,291
www.greenfieldclockshop.com
The last person to work on the clock often takes the blame for everything that was done before. Bush the punched holes and it will look much better and last longer than the punched hole. Bush in a bush works OK if done carefully - use longer bushings and leave the bushings a little proud on both sides and dress them flush and form a new oil sink and no one will ever know there are two bushings in the hole. They may not even recognize that the hole has been bushed at all if you dress it well.
Bergeon bushings usually have a larger diameter and will frequently cover all or part of the punch markings. Even if some evidence of punching remains, these larger bushings will usually hold their shape and stay in place if the reamed hole is correctly sized. And the next person will realize that you at least attempted to clean up the mess.
MARK A. BUTTERWORTH
NAWCC Life Member
Jul 4, 2009
2,538
179
Muscatine, Iowa 52761
Is there a problem bushing the whole plate?
170,822
1,491,259
49,914
Roberthunigan1
2,967
