What period were brass weights used in 19th century tall clocks?
Discussion in 'General Clock Discussions' started by PaulWeber, Apr 15, 2017.
  1. PaulWeber
    PaulWeber Registered User
    Feb 10, 2017
    What period, or style within a particular period, were solid brass weights originally installed in 19th century tall clocks. I really like old solid brass weights, and I'd like to put a set in my clock....so long as it "fits."
  2. novicetimekeeper
    Jul 26, 2015
    4,822
    Dorset
    #2 novicetimekeeper, Apr 15, 2017
    I don't think solid brass weights were ever used in 19th century longcase, certainly not over here anyway.
    Brass cased lead weights were used in the 17th century and early 18th century particularly in London, then lead and then with the relative mass production of painted dial clocks a switch to cast iron
    Edit: Brass weights would be 30% bigger for the same weight, and brass was still very expensive in the 19th century, lead would have been very cheap still.
  3. PaulWeber
    Feb 10, 2017
  4. novicetimekeeper
    Jul 26, 2015
    4,822
    Dorset
    Those are brass cased weights, and it's very unlikely the clock started out with them if it is English.
    Those square door pillars are unusual too.
    If this is English it has a style of post 1830, 100 years later or more than brass cased weights on most longcase.
    Edit If you look at London clocks from the late 17th century/early 18th century they had lenticles in the doors, so you could see the pendulum and weights glinting in the candle light.
  5. PaulWeber
    Feb 10, 2017
  6. novicetimekeeper
    Jul 26, 2015
    4,822
    Dorset
    I'm not familar with clocks of this age so their cases are a bit of a mystery to me, I recognise that square hood pillars are unusual but I wouldn't be able to date the case not suggest a location.
    The weights, well I don't think they are a pair, all the pairs I've seen are very similar in appearance, you have to look quite close to work out which is time and which is strike. They don't look like the really good early London ones.
  7. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    3,613
    Devon
    As Nick has said the answer to the question for British longcase clocks is there is no period when brass weights were typically in use though some clocks weren't fitted with them which would have been at extra cost though the weights in this clock aren't a pair anyway. The case is a nice quality well made one and the dial is an attractive one, in terms of UK longcases it belongs to the last style which is in the period 1830-70.
  8. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Donor
    Jun 14, 2008
    1,223
    Retired from computer program/product/project mana
    Magnolia, TX
    Original "brass weights" in period clocks are lead filled brass shells. Brass was a very expensive commodity back when, still is as I noted when buying some recently. As others have stated in this thread brass shelled weights are not common. It was an additional cost to the maker and ultimately to the customer that didn't show in most tall clocks. That said, some of the more formal English clocks had them, and others noted above, that seemed more of a London area trait than elsewhere. As times changed and tall clocks were superseded by hall clocks with glass fronts and sides brass shelled weights became a requirement. It is uncommon to see brass shelled weights in tall clocks made prior to about 1880 on this side of the pond. It should be noted it was common to use brass weights in regulator clocks, jewelers regulators, and the like much earlier, as they could be seen in these clocks and if seen, they needed to be "pretty".
    Paul, I would guess your clock originally had cast iron weights, given its style and when/where it was made. 40 or 50 years ago importers of antique clocks in this country might well have several hundred clock cases, clock movements, and stacks of weights and pendulums. Very few of them were kept together. The common approach to buying clocks from these folks was to select a case you liked, go find an insert (movement and dial) you like, see if it fit the case semi correctly. If it did, you would then go to the weight stack and select a pair of weights, then find a pendulum you liked and go pay for the clock and go.....
    I remember finding a Thomas Tompion insert in the stack one day at Mudd's Antiques in Columbus IN about 1975. The price on brass dialed clocks was "your choice $180". But Mudd when seeing the Tompion I selected said "oh no, that one is $750". Sadly, I didn't have $750. The major point of this story is a lot of mixing and matching happened over here, I have been told it was much the same in England and on the continent also. So having inserts that don't quite fit, or weights that aren't quite what we expect, and accessories that may be questionable, all happened thanks to bad habits over time. By the way Mudd had over 5000 clocks at one time that I am aware of....so this was not a small mixing bowl. Other exporters and importers behaved the same and also dealt in large quantities of products. "All original?" A hard claim to prove, often incorrect.... and Paul, there is nothing about the clock you picture that suggest is is not the correct insert in the correct case. Only your weights would seem questionable IMO.
Similar Threads - period were brass Forum Date
How were/are keys made? General Clock Discussions Jun 8, 2017
A clock from the period of Jerome's recovery from the Bristol fire of 1845 General Clock Discussions May 29, 2017
Help identify maker of period time and strike banjo clock General Clock Discussions Sep 18, 2015
Looking for period photo of old school room with clock General Clock Discussions Aug 22, 2013
Help identifying Maker and Period General Clock Discussions Mar 7, 2011
