What is this part please!
bunnyh
Jan 7, 2022
I can identify every part but this one! - does it have something to do with the pendulum? It is 5cms in length. I am new to all of this! clock part.JPG
bunnyh
Jan 7, 2022
it is part of the innards of a french drum-head 'slate' clock movement.
wow
Jun 24, 2008
6,186
870
77
Pineville, La. (central La.)
Could be brocot or lots of old American mantle clocks had dial adjusters with those arbors. What kind of clock is it from?
JeffG
Jul 8, 2020
229
65
St. Croix, U.S.V.I.
Looks a lot like a rate adjuster.
It would go through the movement from back to front. The square end would receive a key through a hole in the dial and the teeth on the rear end would mesh with another similar cog at 90 degrees which would adjust the suspension spring up and down slightly through the chops.
JTD
Sep 27, 2005
9,904
1,058
It is for adjusting the suspension spring from the front of the clock with the small end on the key. Used in American clocks only as far as my memory goes back.
Yes, that's what it is, but not exclusive to American clocks. You can find it on many French clocks too.
JTD
bunnyh
Jan 7, 2022
So sorry not to have replied sooner - I was away.
It is from a black marble (drumhead) french mantle clock. You are correct I think in that it appears to be the fast/slow arbor but what threw me is there is no hole in the clock face for it to go through! Something has clearly been replaced - maybe the face. The part just fell out! so I didn't know where it came from. I wonder if the 'Modele Depose' stamped on the wheel of the brocot adjuster means anything by way of dating the clock? Thank you so much for your reply.
bunnyh
Jan 7, 2022
Can you show us the whole clock?
No. But seeing the movement might.
JTD
I don't have a close up of the clock so not much use I'm afraid and the movement is still in bits!!
I'll dig out photos that I took as I went along. It looked just like the typical french movements pictured on this website and you tube with the snail wheel. Looking at it again, the screwed on brass piece with the hole at the top swings out and the end of the brocot adjustment arbor goes through it and rests in a matching hole on back of clock face rather than through it. Strange and rather fiddly to adjust I would have thought.
JTD
Sep 27, 2005
9,904
1,058
Sorry, but I can't follow this at all. I'll look forward to seeing further photos when you are able.
Others may understand better than I.
JTD
captainclock
Mar 4, 2013
415
33
Elkhart, Indiana
I've got an 1860s French Pendule de Paris Clock thats in a wooden case, that the movement is a Japy movement and the dial and movement are also marked Henry Marc and several other related markings and my clock has one of these types of "brocot" regulating adjustments on the front of the clock (mine is at the 12 o'clock position just above the "12" mark on the dial) and it is so small that I have to use a No. 8 Pocket Watch Key to adjust the "brocot" aadjustment on my clock.
See Picture Below.
Mike Phelan
Dec 17, 2003
10,699
251
West Yorkshire, England
As it uses a rack rather than a count wheel for striking it's probably post-1880.
These French roulant clocks almost always have a Brocot adjustment for the suspension, so yours as RB says, has its end cut off.
Ergo, the dial if there's no hole next to the XII it's not originally for this clock.
If you are sayng that the back plate of the dial has this hole it will probably be original, and the actual dial will have been swapped. Dials for these are enamel (glass).
captainclock
Mar 4, 2013
415
33
Elkhart, Indiana
Are you commenting about the OP's Clock or mine? If you're commenting about the OP's then yes, I would agree that his clock is defininitely not as early as mine is (mine uses a count wheel for the strike) but the regulating key hole location still applies to the OP's clock as it does to mine because they used that style of regulating for the French Pendule clocks regardless of their age.
Mike Phelan
Dec 17, 2003
10,699
251
Sorry, it was the mixture of the two threads that got a bit confusing; my post was for bunnyh's clock.
captainclock
Mar 4, 2013
415
33
Elkhart, Indiana
OK, that's what I was thinking, but I wanted to make sure, I was posting the picture of my clock for the OP so that he could have an idea of what that regulating adjustment keyhole was supposed to look like on his clock, I was just providing the information about the maker and retailer of my clock and its age so that the OP and anyone else here knew that my clock was indeed the same style of clock as the OP's clock but just a little bit older, and different maker.
Reactions: roughbarked
173,673
1,516,535
51,879
Nauman
1,062
2,969
