What is this for? Cased set of 48 different sized pulleys?
m33eow
Mar 22, 2006
94
Hi folks,
I'm hoping someone might be able to help me identify this. I'm working my way through my late husbands workshop and he had a number of horological tools, but I've no idea what this is / what it's for.
My best guess is it's some sort of an attachment for a lathe? There's a wooden box with a set of 48 graduated, what look like, brass pulleys on steel shafts. I can't see any manafacturers names anywhere, but each of the units is stamped consecutively on the top from 1 to 48.
Any thoughts gratefully recieved!
very many thanks
Anne
gmorse
13,151
2,528
Hi Anne,
This is a set of turning arbors, designed for use between dead centres in a lathe. Wheels or other circular parts which can't otherwise be held securely in a normal watchmaker's lathe are fitted friction tight on the appropriate sized steel arbor, all of which are slightly tapered, and can then be rotated with a bow on the pulley.
m33eow
Mar 22, 2006
94
Thank you very much Graham, very much appreciated!
very best wishes
Anne
170,925
1,492,206
49,994
Jennifer123
2,967
