What is the largest clock that can be constructed with Sherline equipment? I plan on getting the the 4400 lathe and the 5500 mill package with all the accessories. What limitations would I have when it comes to clock construction, what would be the largest gears that could be made? Thanks.
Barry, Here is a link to Sherline's website which says the largest diameter the lathe can turn is 3.5". A riser block accessory is available that will allow this diameter to be increased to 5.5" Allan
Barry, If you post a question regarding Sherline's equipment on the tools forum. I bet Jerry Kieffer will be able to give you all the information you require.
With a little creativity, the sherline mill can be configured to turn larger parts than 5.5', but smaller equipment is really best for machining smaller parts.
Russel, yes for sure it would have taken more than "a little creativity" to turn parts larger than 5.5 FEET... I was hoping for a picture
When I saw my mistake I had to laugh. I was only off by a factor of 12! On another note, keeping in mind that I haven't ever built a clock, I would try to keep any turning needed down to 1.75" diameter when using Sherline equipment. That is the largest size that can be comfortably turned over the crosslide. And I would want to be comfortable when trying to make a part with great precision. Someone with greater skill would be able to be "creative" and successfully machine larger parts on these little machines.
Here is a photo of a clock that was made on a Sherline. For reference, the description page is a standard 8.5 X 11 sheet of paper: A few months after I took this photo this clock was awarded a first place at the 2012 National in Pasadena, CA.
