What Is Damaging These Teeth?
Petec
Newbie
Jun 5, 2014
Nashville TN
See attached. I don't know if this just started or is the result of 70 years of wear.
Jim DuBois
Gibbs Literary Award
Jun 14, 2008
3,315
899
Magnolia, TX
That is the result of many years of use involving too soft of brass coupled with an overly strong spring. The wheel needs to be replaced.
13,739
1,415
Pete,
When they are that far gone, I would recommend having a new wheel made, or start looking for a good used wheel assembly.
Also, after you deal with the worn out wheel, switch to a .165" strength mainspring. This will lessen future wear.
bikerclockguy
Jul 22, 2017
678
56
Also, since the wear is uneven(goes from heavy to slight), I’m guessing you probably have a bent arbor as well.
Petec
Newbie
Jun 5, 2014
Nashville TN
Is there anyone on this forum that can make a new wheel?
Petec
Newbie
Jun 5, 2014
Nashville TN
The mechanism is "Ansonia 5 1/2"
I made 5 measurements of the diameter as shown in the picture.
They varied from 59.65mm to 59.77mm.
The thickness is 1.48mm
Petec
Newbie
Jun 5, 2014
Nashville TN
I will check into that. Many years ago the clock would stop at random times. I noticed one of the wheels was always in the same position when it stopped. I used a dial gauge to find the point that needed to be corrected and nudged it back.
Rob Martinez
May 3, 2013
164
15
Might be showing my ignorance here but the Butterworth WWW page seems to have the biggest selection of parts/wheels bar-none. Maybe an email to them with the OD and # of teeth.... Worst case they say no....
Reactions: Petec
Jim DuBois
Jun 14, 2008
3,315
899
Magnolia, TX
Butterworth stocks parts for modern clocks. I would not expect to find a great wheel for your clock there. And yes, there are people here who can make such a wheel, but it will be far more cost-effective to find a replacement off a loose movement. I suspect having one custom made will cost you $100 or more.
R. Croswell
10,989
1,119
www.greenfieldclockshop.com
www.timesavers.com sells a replacement main wheel that fits some American movements.
In addition to the causes of the damage already mentioned - brass that's too soft, too thin, and too much power - worn pivots/pivot holes at both the T1 and T2 positions, and accumulated dirt were likely factors. Properly designed, the main wheel teeth push the trundles of the T2 lantern pinion, there is very little sliding action between the tooth and the pinion. When the pivot holes wear the wheel and pinion are no longer properly aligned and the wheel teeth are forced to slide against the pinion rapidly increasing the rate of wear. In the OP's example, the brass that is missing was likely worn away by improper gear to wheel alignment caused by pivot wear and accelerated by dirt and metal dust acting as grinding compound. The brass that was 'pushed up' but is still there was caused, as stated by others, by too much force on a wheel that was not strong enough to take the loading over time.
Reactions: Petec
165,376
1,439,399
86,181
Kevsun
2,873
