What happened with German letters?
Discussion in 'Message Board Help & Notices' started by tarant, Aug 12, 2014.
  1. tarant
    tarant Registered User
    Jul 6, 2008
    1,154
    24
    Neurohorologist ;)
    Wroclaw
    #1 tarant, Aug 12, 2014
    Since the relocation of the Forum servers German letters disappeared... Instead ä ö ü ß ü you can only see symbols:
  2. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    149
    deceased
    #2 harold bain, Aug 12, 2014
  3. Tom McIntyre
    Tom McIntyre Technical Admin
    Aug 24, 2000
    82,201
    1,506
    176
    retired SW dev
    Boston
    #3 Tom McIntyre, Aug 12, 2014
    Is it supposed to say Börk Master Clock?
    We had two different character sets in the English language settings (which is the only language we support). Characters were being converted between UTF-8 that was used by the editor and iso-8859-1 that was designated to display pages.
    I changed the display setting to UTF-8 because I had no means to readily change the other.
    utf-8 will display all the European characters, but the encoding is different. I do not know how to generate the accented characters on my keyboard, so I use the insert function in MS Word to create them.
    I am trying to find some way to do an edit of the database to make the conversion to the UTF-8 encoding from the bits and pieces that are currently iso-8859-1.
    Critical single instances can be corrected by an Admin or Moderator but there are many thousands of affected characters.
  4. tarant
    Jul 6, 2008
    1,154
    24
    Neurohorologist ;)
    Wroclaw
    #4 tarant, Aug 12, 2014
    No, should be Bürk. This symbol � replaced both ö and ü .
  5. shutterbug
    41,807
    925
    Ö Ü can be generated with Alt 153 and Alt 154. For a handy reference you're welcome to this. Hold ALT while you input the number in the left column
  6. Tom McIntyre
    Aug 24, 2000
    82,201
    1,506
    176
    retired SW dev
    Boston
    #6 Tom McIntyre, Aug 12, 2014
    I also found that my keyboard supports ctrl/:,o and similar keystroke sequences for accented letters. That does not work inside this CKEditor interface.
  7. John Hubby
    Sep 7, 2000
    12,251
    204
    The Woodlands, TX
    #7 John Hubby, Aug 13, 2014
    If you are using an Apple computer, the option key held down with pressing the appropriate keyboard letter or number shows the German correctly: Söhne, Schloß, Gebrüder, etc.
  8. tarant
    Jul 6, 2008
    1,154
    24
    Neurohorologist ;)
    Wroclaw
    BTW. French letters are destroyed, too :(
    FireShot Screen Capture #740 - 'Post Your Farcot Clocks Here - Page 20' - mb_nawcc_org_showthrea.jpg
  9. Tom McIntyre
    Aug 24, 2000
    82,201
    1,506
    176
    retired SW dev
    Boston
    #9 Tom McIntyre, Aug 17, 2014
    The problem .involves all languages that are represented in the 256 character UTF-8 character set. Some parts of our software were using UTF-8 while other parts were using the 16 bit characters for accented characters. The conflict was causing problems and the only available solution was to use UTF-8 everywhere. Eugéne Farcot is available as is Eugène Farçot. The current damaged text will be repaired as soon as i find the proper tool. I don't want to retype the old posts and I don't know what all the words should be. ;)
  10. kirxklox
    kirxklox Registered User
    Dec 17, 2002
    4,387
    56
    Dardanell, AR
    You should be able to correct this problem using the HTML editor. However, that does require oversight.
